Results 1 to 3 of 3
Thread: I have a Jim C Chip and had q's about fuel
    Default I have a Jim C Chip and had q's about fuel
    Had it in my car for years. I remember directions saying only run premium fuel. Saw a post on that 'other' board saying 535is because of their lower compression actually do run better on 87. Will this screw up my driveability with a non-stock chip if I run 87 or 89? Thanks.
    nf
    '90 535iA
    Jul 2005
    New York
    if the directions say run premium, then by all means run it. m30's stock chips are tuned for 87. but once you replace the chip, its premium all the way.
    You're my hero.
    Default For the same reason that they are claiming that you run better on
    regular with the lower compression(ie because it contains more energy per pound) you cannot run regular with a chip. The m30 does not have a knock sensor and will not adjust its timing depending on what fuel you have. Newer engines will so the fuel usage is a little more flexible. One of the biggest gains you get from a chip is advanced engine spark timing. By advancing the timing on an m30 it then requires higher octane to prevent pinging or preignition
    Quote Originally Posted by nealf
    nf
    '90 535iA
  1. Replies: 8
    Last Post: 09-05-2005, 05:41 PM
  2. Replies: 27
    Last Post: 09-02-2005, 09:02 PM
  3. EAT chip fuel economy?
    By pundit in forum 5 Series BMW
    Last Post: 12-21-2004, 07:03 AM
  4. Eat Chip And British Fuel
    By DANGEROUS DAVE in forum 5 Series BMW
    Last Post: 10-22-2004, 07:58 AM
  5. Replies: 1
    Last Post: 05-14-2004, 09:24 PM
