Results 1 to 5 of 5
Thread: Ordering Struts for an E34 19mm or 22mm?
    Dec 2005
    DC Metro
    Default Ordering Struts for an E34 19mm or 22mm?
    Ok, I searched RealOEM and through the forums and I couldnt find the answer. I have a 5/92 build date 525i and I cant find anywhere what size struts I need. Is there some list that will tell me if I have 19mm or 22mm bolts?
    Austin, TX
    give BMA a call. 1-888-262-3911, speak to Patrick. He helped me when buying my Bilsteins...knew exactly what i needed by production date.
    Benneton (United Colors of)
    ALWAYS measure the dust cap, and the nut yourself. DON'T rely on BMA, or the ETK, or production date, or bilstein/boge/&c. &c application catalogue, as an application catalog won't ammend a return policy for you if your car was a production oddball. measure the items, then use the production date to find what you need.
    ditto on Ryan, also I believe the Bilstein sports have a spacer that can be used in either size nut.
    Meridian, ID
    Measure twice, order once! New BMW axiom. Seriously, measure the nut. You never know if someone changed the strut bearings to a newer/older size. Just pop off the plastic cap with a screwdriver and put a spanner (open end wrench) to it. Real ez.
    Mike Holbrook
    Meridian, Idaho
  1. Shock upgrade Koni... 19mm vs 22mm nut
    By smcgowan in forum 5 Series BMW
    Last Post: 01-06-2010, 09:42 PM
  2. ordering from abraham's motorsport...
    By misfortune in forum 5 Series BMW
    Last Post: 08-07-2007, 11:27 AM
  3. Shock sizes 19mm, or 22mm
    By Felixdacat in forum 5 Series BMW
    Last Post: 02-09-2006, 05:51 PM
  4. 19mm nut or 22mm wich one??
    By Dan-ny-m398 in forum 5 Series BMW
    Last Post: 03-05-2005, 11:36 PM
  5. Need help ordering parts
    By BennyM in forum 5 Series BMW
    Last Post: 08-19-2004, 10:40 PM
