Hi muttley, In Australia we had taller springs for rougher roads. The online ETK lists them as special items. I'm not sure if there was much in it tho. I just put m-tech springs in, so you can have my old Aussie e34 springs if you pay me for a decent box and shipping. I also have a set of Bilstein Automatics for the front. You would need to get Bilstein HD rear shocks if you want to suit tall springs.
If you have Bilstein shocks (or any other shock with a removable spring seat ie not Sashs/Boge or most others), you can raise the rear (only) by using exact-sized seat-raising steel rings or tower mount spacers. You can make spacers for the front towers too, but opne needs a lathe and application to do it right.
I am going to make a set (seat rasiing rings) for mine to take the weight of my tow bar and give me 20mm or so extra height at the rear. I can do 2 sets if you like- you can safely go up to 2" higher than stock. But you have to tell me mich higher over stock you want them. With the springs, you can use e32 ones but these are for really for a much heavier car with a different weight distribution... so it might give you too much height or any number of other strange results...
Remember thogh, the rear should look a bit lower than the front for optimum handling...
Nick
