Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Heater always blowing warm
    Jul 2005
    Hamilton , Scotland
    Ok I took a hammer to the valves today and the drivers side one seems to work properly now, I can hear it clicking away. I can get fully cold air from the drivers vent now which I couldnt before.
    Passenger side one seems to be knackered though, but its stuck on almost cold so its not really a problem.
    Hope they stay working so I dont have to replace the valves.
    QUESTION - does a 1991 525i M50 have an Aux water pump ? I couldnt see any sign of it. Maybe it was only the 535i ? Or im blind
    1991 BMW 525i sport manual, BBTB, Mintex Extreme Pads, Bilstein dampers and Eibach springs,Viper2 chip, //M5 Replica.
    Minnesota
    Should have the aux pump, check the link, http://www.bmwe34.net/e34main/Mainte...eaterValve.htm
    look there at the first picture that shows the valve assembly attached to the aux. pump. They come out together if you're refurbing this item. Then you separate the two components. Check the wiring to the pump, this could be the problem, mine was completely corroded at the pump and needed replacement. Perhaps you will be luckier?
    JonE
    Asheville, NC
    try flushing the heater valve. there is a website out there (don't remember where, sorry) with instructions and pictures and everything!!
    probably not the heater sword thingy, and the coolant leak would cause your heat to be cool, not your a/c to be warm.
    Tony
  1. Replies: 22
    Last Post: 01-29-2007, 05:41 PM
  2. no heater fan blowing
    By 87esir in forum 3 Series BMW
    Last Post: 06-15-2006, 07:48 PM
  3. Heater always warm?
    Last Post: 07-20-2005, 11:05 AM
  4. Heater Fan blowing fuse. Whats the best guess?
    By CJK525iT in forum 5 Series BMW
    Last Post: 06-20-2004, 08:03 PM
  5. Replies: 2
    Last Post: 03-24-2004, 01:53 PM
