Rear subframe mounts, rear pitman arms...The pitman arms are easy to get to and check for play, the subframe mounts will require you to remove the brace in order to see the mount.
The pitman arms are easy to replace, the subframe mounts aren't, you'll need special tools, and even then sometimes they have to be cut out.
You can see the parts and their location at www.realoem.com
