Have you checked your sway bar links?Originally Posted by t_marat
These tend to make a light metallic clinking rattle.
http://www.realoem.com/bmw/showparts...45&hg=31&fg=10
Stabilizer link - Item no 6.
In the past several weeks I nearly completely overhauled the front suspension. These were changed:
Lower and upper thrust arms. Both right and left.
Stabiliser Link, right&left.
Steering ball joints, all of them 4pcs
Steering rubber mounting, number 15 in the picture
http://www.realoem.com/bmw/showparts...34&hg=32&fg=25
Front suspension no longer make those horrible noises. I only get some slight vibration on the steering wheel only if I ran over some roughness at high speed. I was advised this was due to my steering box having some slackness. I told the mechanic of the nuts on the steering column and the adjustability of the steering box. But the guy was telling these won't work, that he tried these on a lot of BMWs.
The worst part is that I am starting to get some other noise. Its different, and I sometimes get that noise over flat surfaces or when I am braking. While braking, just when the car is about to stop, I get that clinking (not clunk) noise. I went back and had them to recheck, everything seems to be fine.
1994 520i with M50 engine, manual transmission and air conditioner.
VIN: GG45422
yes, they are new, febi.
VIN: GG45422
securely in their tapered opening on the steering knuckle?
Check for cracks on the inner fender brace. Located just behind the wheel and splash shield. See photo in post 5:
http://www.bimmer.info/forum/showthr...er+brace+crack
Anthony
03/64 production
