Hello everyone, im back... kind of - I am forced to work on my car next friday... and I CANNOT WAIT TILL I DO IT
My current problems are:
DRIVERS DOOR!!! - I am starting to be a nervous wreck driving that car... even chillout music wont help sometimes *ding* "door open" *ding*....
Car is fully stock (im starting to not like the way it looks with the stock springs, esp front - so I need new springs);
Fluids are old (even oil)
Engine leaking oil
Rear wheels out of alignment (by about 1-1.5 deg.)
LSD is whining (but I cant do nothing about that...)
Speedometer needle was jumping around, problem went away after i filled up LSD with fluid - nopefully not going to come back
Rear shocks of unknown date
Main auxiliary belt of unknown replacement date
Green coolant inside the engine
Oil outdated (~5020 miles on it)
Exhaust leaking out of the center resonator
Cosmetically car is in fair shape... ill be honest - rust under the doors and at the bottom of fenders, fenders rusted through
Heater core leaking
Minor electric disconnections, etc..
My control arms were a temp fix... so right now i am tihnking, while im building a car.. basically - why not go ahead and replace those while im at it?
Erratic idle
What I will need:
Most importantly:
Exhaust (which i have a question about)
Rear view mirror on pass. side
Fenders
Valve cover gasket
Driver's side rear trailing arm (preferrably the whole assembly)
Fluids, Filters, belts (no timing belt - to all you M20s haha)
Heater core
Control arms (if i can get good ones for cheap)
Sport/lowering springs (if im lucky)
I really want to swap my transmission with a manual 5-spd (if anyone has a kit, give me a lead for a cheap one? )
Driver's side locking mechanism (the ENTIRE thing)
Rear shocks
Rear brakes
Guibo
Driveshaft bearing
LSD (maybe later)
REALLY BAD PART: My budget - $400.. $600MAX (if anyone can help me with used parts.. lemme know )
now for the exhaust question:
My exhaust is leaking out of the central resonator, a part which many BMW people recommended me to bypass in the long run. I want to find out what pipes are the best to use on my car. I looked around autozone and found a bunch of different ones. Can you guys lead me to a direction of a good one, and a best way to possibly put one on there without welding?
NOTE: I know that car has lots of problems, BUT I bought it for that purpose.. to learn everything aobut BMWs on it I just hope that it doesnt take that much money in terms of parts.. and I know if i do all of those repairs, I will be pretty much able to do anything to it. I am hoping to follow jon and SC or Turbo it at some point later on, once I actually get a steady income and/or get out of college.
Thank you all. This is my project
