I see now
You are experieced with graphics software. Perhaps you could learn much of the program quickly. Your graphic also in an inside reference that is not clear to us non-tubo people. Interesting.
Originally Posted by
Jon K
No I did mean learned in 2 hrs. I have been using photoshop for over 6 years now - I subscribe to lynda.com tutorials ; i sifted thru a couple of segments of their tutorials and learned Live Paint, point editting, etc. I feel more than comfortable with Illustrator now, I never gave it a chance, but do now that I had a reason to use it.
I do know AutoCAD fairly well also.
The algorithm isn't supposed to make sense in the way you guys are thinking - they call turbos "snails". So SNAIL + TURBO makes no sense in this example, as they're one in the same. It's supposed to signify a SNAIL + MASS_AIR_MOVEMENT = TURBO, thru association of SNAIL==TURBO.
Also, the problem I found with making the outlining in thicker lines is that when the image is scaled down, let's say for a hat or vinyl sticker, the 2pt thick lines are too wide and detail is lost.
