Stephen, I'll chime in here if I may. I think you have the terminology wrong on the word "strut". The strut is the device that holds the shock and spring in place. I've never heard of someone replacing it unless it's been bent in an accident, but I've heard of deliberately bending this baby to give you more camber on the front wheels.
Being a
s advocate here. Why go for lowered springs anyway? The camber at the rear will be increase (more negative camber) causing the inside of the tyres to wear faster which can only be fixed by rotating the tyres more often which will have to come off the wheels or install eccentric bushings in the trailing arms which is very time consuming job. What are you doing for strut mounts at the front?
Also with a lowered front spring, it maybe so long that you cannot get your floor jack under the front crossmember when jacking up the car (thats what happened to me). Not a major deal just a bit annoying.
As for the thrust arm bushings, I think Scott H is right, the m5 ones are the ones to get. I asked about this on here with limited responses (I was curious also).
http://www.bimmer.info/forum/showthread.php?t=17705
The reason being, your going to upgrage the bush from normal to 750i, so why stop in the middle ground?
Maybe this article can also state that you can't have your cake and eat it also. Meaning any upgrade that contributes to a "more sportier feel" or stiffer ride will contribute to an increase in noise, vechile, harshness. You will feel more bumps in the road and it won't be as comfortable to ride on. I'm going to finish this off and get out of here; what are you doing for swaybars?
