I took off the intake to reseal it and change the PCV plate. I used the ample info on this board to get the step by step instructions. My problem is that it will not run properly. I cant even get it to run enough to see if I have a vacum leak. It is pumping too much fuel in. The plugs are soaking wet. I put new plugs in to no avail. I cannot find anything I did not seal back up or did not plug in. If I hold the throttle part open it will chug to life but run beyond lumpy and stall if I let off on the throtlle. Any suggestions would be helpful. The good news is, the 540 being down was a good reason to drive my '66 911 around today. So I am not too bummed about not getting the 540 running.
Aaron
