Originally Posted by Cambridge
It is a hassle. The real reason to do it it to, IMHO, is to replace the rubber O rings (if that's what you call them) that seal the cooler pipes. Once they leak the jig is up. You could just let thedog lie if it's not leaking. The catch 22 is that it's pretty hard to tell until its too late. If you have trace coolant loss, and the tranny cooler lines and front end are tight, that's prolly where it went.
If you have an automatic, don't forget to r&r the tranny cooler hoses. It's really hard (but not impossible) unless you have the manifold and coolant reservoir off. I consider it routine when doing the pcv. They will leak eventually. Use a nice hose clamp, and then a heavy duty cable tie on either side of the clamp on both inlet and outlet- but especially on the inlet, as that's where all the pressure is.
Your car is already stunningly beautiful. Please post large engine porno pix for me when you get the valve covers. Are you going to stay with that cosmoline color?
