i dont follow.
i dont follow.
I mean MAF meter connectes to AIR box by 2 hex screws, but the joint is like MAF 2 pipes join togther and pipes you turn(twist) left and right ( kinda of motion you would use to open or insert a hose into connector)
Regal, Did you get what I am talking about now? If now I will try to take pic this weekend.
Akhil
It sorta swivels a little bit, but that is ok and normal. Any pinching of the wire, or air leaks in the boot, either before the MAF, but especially after, is not good though.
o/______\o
(Oo=00=oO)
here in this pic
http://www.realoem.com/bmw/showparts...48&hg=13&fg=20
screw number 5 holds and presses MAF meter against air box, but if I hold MAF meter by hand and try to twist then moves about 15 to 30 degree clockwise and then anticlockwise.
I am think is that the way its suppose to be or I have some seal/ring/gasket gone bad?
Thanks
Akhil
Normal.
It's so you can take off the air filter box (which requires some swivel clearance) without disconnecting the MAF.
You should have 45-60 degrees of swivel, but no play back and forth against the mount to the box.
o/______\o
(Oo=00=oO)
from that joint?
.Originally Posted by tim
o/______\o
(Oo=00=oO)
