Results 1 to 8 of 8
Thread: MAF meter twist around Air box..Any idea how to fix?
    Houston, TX (USA)
    Default MAF meter twist around Air box..Any idea how to fix?
    Hey guys
    I noticed today that my MAF meter twist aroung air box, mean its loose and might be sucking unfilltered air from there, but now unmetered though. I just want know what to expect when I open air box to MAF meter joint.
    Is there any gasket/seal between them which need to replace? I looking at Real OEM but didn't find any such part. How does it seal that joint?
    Thanks a lot in advance.
    Akhil
    i dont follow.
    Houston, TX (USA)
    Default I am sorry I don't have pic. but I don't know how to explain let me try.......
    I mean MAF meter connectes to AIR box by 2 hex screws, but the joint is like MAF 2 pipes join togther and pipes you turn(twist) left and right ( kinda of motion you would use to open or insert a hose into connector)
    Regal, Did you get what I am talking about now? If now I will try to take pic this weekend.
    Akhil
    It sorta swivels a little bit, but that is ok and normal. Any pinching of the wire, or air leaks in the boot, either before the MAF, but especially after, is not good though.
    o/______\o
    (Oo=00=oO)
    Houston, TX (USA)
    Default Its before MAF meter.....
    here in this pic
    http://www.realoem.com/bmw/showparts...48&hg=13&fg=20
    screw number 5 holds and presses MAF meter against air box, but if I hold MAF meter by hand and try to twist then moves about 15 to 30 degree clockwise and then anticlockwise.
    I am think is that the way its suppose to be or I have some seal/ring/gasket gone bad?
    Akhil
    Normal.
    It's so you can take off the air filter box (which requires some swivel clearance) without disconnecting the MAF.
    You should have 45-60 degrees of swivel, but no play back and forth against the mount to the box.
    o/______\o
    (Oo=00=oO)
    Houston, TX (USA)
    Default Thanks guys, how can I make sure there is no air leaking ...
    from that joint?
    Quote Originally Posted by tim
    *but no play back and forth against the mount to the box*.
    o/______\o
    (Oo=00=oO)
  1. seatback twist
    By crankin in forum 7 Series BMW
    Last Post: 03-02-2006, 09:16 PM
  2. help with seat twist fix
    By 95-540iLE in forum 5 Series BMW
    Last Post: 12-29-2005, 09:23 AM
  3. swapping tires with rims: good idea / bad idea?
    By BennyM in forum 5 Series BMW
    Last Post: 04-03-2004, 07:29 PM
