Originally Posted by
tim
A clue to the problem may be the fact the car runs in "sport mode" until it is warmed up (i.e.: the o2 sensors start signaling.) In plain english, the mixture is hard set at "rich" until the o2 sensor feedback loop, called "lambda" begins. It can take alot of time for the o2 sensors to warm up, even when it isn't cold out, but even longer of course if it is below freezing.
The valves on your car are "VANOS", which basically means the intake and exhaust valve clearances are hydraulically actuated and continuously variable, and there are two, one for each bank. In the absence of the Lamda signal from the ECU, both banks are on fixed timing. Not that it is common by any means, but perhaps that would be a place to investigate- i.e.: maybe one is slightly off. You mentioned it sounds like it's running on four cylinders, and if the static timing were off enough... and that would help explain why after warming up it runs fine.
Unlike the m30's and m50's the PCV plate does not exhaust back directly into the intake manifold all the time, but rather the plate acts as a filter, which maintains a certain level of crancase pressure, and vents only when a certain pressure is exceeded. I doubt you're bathing the intake manifold in crancase vapor unless your rings or cylinders were heavily damaged, and allowing constant blowby. Sure, the ICV gets greasy in time, but I would think a problem in that area would manefest whether it was cold or warm.
You didn't mention whether you changed the plugs. I have had cars improve greatly by just going back to the stock, two-electrode (f7ldcr), away from the ngk 4 electrode style or any of the various platinum "upgrade" plugs. Not a knock on NGK by any means, just an observation.
After all the work, did you do the "shogun reset"? If not- do a search. It has done wonders for some. It's a standard procedure for me, and I do it anytime I do something that requires cutting the power supply.
Finally, on a YMMV basis, I have had great success in cases of leaky injectors, carbon buildup, etc by doing the "seafoam" treatment. Look, some people think it's ********, but I think this stuff is truly valuable and not some mystery snake oil. Do a search on that. I'd remove the connection of the rubber fuel hose to the hard hose, over by the fuse box, and flood the top end with it-( I mean a couple pints here, not gallons!) wait awhile. start it up in a *well ventilated" area! you won't believe the smoke. Then change the plugs, change the oil, do the Shogun reset and see where you are.
I'm sure some greater minds will chime in soon so good luck and welcome.
edit- oh yeah, what Jeff said too! I just saw it after my post came up.
tim
