Results 1 to 8 of 8
Thread: Rocker arm shaft plugs
    good stuff. Love your handle...Bellicose Right Winger...lol...hillarious. Sounds correct..the rocker shafts are hollow and have oil holes for lubrication to the rocker shafts. Obvious question then F1 FAN...is how do your rocker shafts and rocker arm bores look if you believe your head rebuilder and the plugs were nowhere to be found to begin with? In any event you do want to replace them for the good reason stated by our bellicose messenger. I would carefully have both shafts and rockers mic'ed for size. Some change rocker arms and shafts when rebuilding an M-30 head as a general rule.
    George
    Mar 2004
    Glad to hear you like it George M. You too can get one if you want.....all you have to do is suggest that an OT post, taken way out of context is mere Liberal Whining and you'll be tatooed like I was. I'll wear this like a Badge of Honor.
    Paul Shovestul
    Quote Originally Posted by George M
    George
  1. Remove plug from end of rocker shaft - M20
    By myles in forum 5 Series BMW
    Last Post: 11-12-2007, 10:56 PM
  2. Help Please!!! Rocker arm shaft
    By clhorton in forum 5 Series BMW
    Last Post: 09-22-2007, 09:07 AM
  3. How to pull rocker arm shaft?
    Last Post: 03-09-2007, 08:38 PM
  4. Help with Rocker Arm Shaft placement
    By DanH in forum 5 Series BMW
    Last Post: 01-12-2006, 10:59 AM
  5. Removing Rocker Arm Shaft(s)
    By Hector in forum 5 Series BMW
    Last Post: 03-01-2004, 04:38 PM
