Results 1 to 10 of 10
Thread: ARRRGH!! I mean, um, radio help. Please.
    Dec 2005
    Nashville, TN
    Default ARRRGH!! I mean, um, radio help. Please.
    OK, so I took the plunge and bought an Alpine HU with an iPod adapter to replace my factory tape deck, having discovered that the Alpine has a setting for amber illumination that's a perfect match. Very exciting.
    I also bought a Scosche wiring harness adapter, because Circuit City in my area no longer carries Alpine stereos or accessories (ref this thread) and I thought I would be in good shape. Spliced everything together, color to color, plugged in new HU, powered it up, HU gets power, all the buttons work ... no sound. Dammit. Hmm. Went over to Anton's site and read a bit, realized I needed to send a signal to the amp. OK, too easy. Hmm, amp wire is a teeny coax type. *shrug* Cut off the metal bit that plugged into the factory stereo, spliced in Remote On wire from Alpine HU, no joy. Moved to ignition wire from Alpine HU, no joy. $#%@#$@$^%$#%!@#$@!#%#$
    Any ideas? I'm losing my mind here. I'm thinking maybe the amp coax wire carries power (center wire, copper) and ground ("jacket" wire, aluminum / silver) and I need to ground it somehow? Please advise.
    Oh, 1995 525i, 10-speaker factory stereo. And I'm not interested in re-wiring the whole car, thanks.
    -Zak-
    1995 525iM - 131k - Alternator play, broken s-belt
    1995 525iA - 147k - Tensioner weirdness, broken s-belt
    2001 Intgra GS-R - 130k - spun bearing
    2002 Honda Odyssey - 80k - fragged transmission
    baton rouge, loserana
    theres a seprate wire for the triggering of the amp in the main radio plug, the coax is something else the pin out should be somewhere on the board
    Dec 2005
    Nashville, TN
    OK, I'm pretty sure I can find the trigger wire. What's the coax for?
    the little dinky one i think is some propriatary signal
    Quote Originally Posted by ProZak
    it's on the old pre nav cars going back to the early 90s too but not all
    Quote Originally Posted by cschollum
    maybe for a gps signal, because that HU has capability for SAT radio
    should all these wires be labeled?
    Wellington,New Zealand
    do you get sound if you play a cd?If not maybe the rear window/antennae thing....
    its mentioned about halfway down here
    Gone but not forgotten
    Dec 2005
    Nashville, TN
    Success! Remote amp wire on the Alpine (blue/white) into (blue) wire on the adapter (pinout 16) -- only wire, FYI, that is not a perfect color match. I'm glad I didn't fry the amp with 12+ volts into that coax thing, just sorry I cut it. Harder to put the factory stereo back in when I sell the old dear, 10 years from now.
    Oh, well. Now I get to much with iPod integration. Thanks a bazillion for the quick assist; this board *rules.*
    i couldn't remember the factory wire color on the 91 and up cars, i didn't think it stayed white like the 90 and older, blue would been my first guess but i didn't want to tell you the wrong thing and it's easy to find a pin out. good luck with the pod
    Aug 2004
    Southern New Hampshire
    I just went through the same ordeal with my 93. I got a harness that connects into the factory radio connector from Circuit City and then soldered the connections from the Alpine unit to it.
    The blue wire from the CC harness was labled for power ant but was really powering on the amp. Connecting it as it's labled left me with a nice working radio but no sound when playing CD's or the iPod.
    Moving the blue/white connection (Amp/Remote) from the alpine over to the blue wire on the CC harness corrected this.
    The iPod adapter works better than expected. I haven't seen the 700MB limit that everyone's talking about. Maybe my playlists were up to snuff already?
    Dec 2005
    Nashville, TN
    Quote Originally Posted by DanQ
    *shrug* Dunno, but mine is working like gangbusters. I'm quite pleased.
  1. Need help with Radio
    By blackpawn5 in forum 5 Series BMW
    Last Post: 02-10-2007, 09:09 AM
  2. Radio lights - source? Not Radio Shack
    By scott 4991 in forum 5 Series BMW
    Last Post: 12-29-2006, 05:55 PM
  3. Radio
    Last Post: 09-17-2005, 03:57 PM
  4. Arrrgh: Don't Buy Dunlop Sp Sport 2's!!!....
    Last Post: 06-12-2004, 10:18 PM
