Results 1 to 8 of 8
Thread: obnoxious squealing
    Bay Area, CA
    Default obnoxious squealing
    hey guys,
    When its cold out, or on some cold starts, the ol' m20 squeals like when I try to drive off. Not at idle, just when hitting the gas.
    I've replaced all belts, water pump, fan clutch...it still does this
    it's extremely loud - and sometimes doesn't stop for quite a while. What could cause this?
    I thought it was the PS pump, and I replaced the fluid in it - but no luck.
    Any ideas??
    thanks!
    Sep 2005
    Goulburn Australia
    The only thing I can think of is belt tension being effected by the temperature but I'm sure you've already covered this aspect. Changing the fluid in the PS pump wont solve your problem.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Sep 2005
    Goulburn Australia
    Just another thought. What about worn bearings up front? I see that you've replaced a heap of things though.
    Cheers
    Wingman
    NSW, Australia
    exactly, with belts off turn and twist the idler pulleys and feel for bad stuff, same with the steering pump and the waterpump...any roughness or non smoothnmedd should show you the problem
    Bay Area, CA
    Well I changed the PS fluid because the pump was squealing at high rpm. (similar squeal,butnot quite the same)... the fluid change fixed THAT problem.
    Bearings.... Alternator, AC compressor.... how in the world should I go about checking those???
    Thanks for the idea!
    remove the belt and twist and turn the pullys, anything feelinf funky usually is.
    Bay Area, CA
    I used one of those things that light up with vibrations. I have no clue what its called. But I let the engine run, and stick the thing on various parts trying to determine the squealing/noise/vibration. I jackpotted right on the pully's.
    www.KaRealtySF.com
    Default Same for me, but I used a car stethoscope
    to isolate the problem to the pulley.
    Quote Originally Posted by liquidtiger720
  1. Squealing, Whining, Steering, Engine?
    By nirvana19 in forum 5 Series BMW
    Last Post: 03-19-2008, 12:28 PM
  2. alt not squealing anymore...
    By timandbim in forum 5 Series BMW
    Last Post: 02-09-2008, 12:50 PM
  3. Squealing on right turns
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 07-13-2007, 10:38 AM
  4. squealing sound at the driveshaft
    By grave77 in forum 8 Series BMW
    Last Post: 01-03-2007, 05:11 PM
  5. Squealing Brakes
    By hdaemon in forum 5 Series BMW
    Last Post: 07-25-2004, 08:58 PM
