Results 1 to 10 of 13
Thread: Auto tranny trouble in cold?
    Toronto
    Default Auto tranny trouble in cold?
    Over the past week, the tranny light has come on during cold starts in the morning (-5 degrees Celcius) in my 1992 e36 325i 4DR. The tranny would skip 1-2-3 and go right into 4th? After driving like this to my coffee stop, I would come out the tranny light would be off and the tranny would catch all gears properly. This went on for 5 days until one morning (this tuesday = really cold), the tranny light was on all day long and no 1,2, or 3?
    Immeadiately I took it to my old Scot Bimmer specialists (old dealer guys) and they said probably low fliud. Left the car over night they scanned the error code, checked the fliud and it was two "cups" low = not the problem. The error code came up as "transmission pressure" but what does that mean? Even they didn't know!
    The car was kept indoors that night and when he test drove it in the morning, it ran fine? But after being left outside all day the problem came back, no 1, 2 or 3?
    There are no leaks and fluid is proper and they don't know what to do? Anybody out there have any ideas? Please advise ... I miss my car! Thanks!!!
    Western Germany
    Default Transmission Empathy
    Quote Originally Posted by amarentic
    I am having the same issue...or I was, rather, and am now having it again. I was having all sorts of shifing problems, but no transmission light (I think I have a "simpler version" of the on-board computer, not that I could read it in German anyway).
    I took my '92 325i 4 door to our local "self help" garage for a look when it started doing this, as I had owned it exactly 2 weeks at that point. The seller told me that he'd had the transmission serviced just before I bought it (warning lights, anyone?). With the tranny good and warm, I lifted the car and opened the check plug (no dipstick, which still baffles me). Fluid did come out...so I replaced the plug, dropped the car and started it. After going through the gears slowly, I re-raised the car, opened the plug and filled the pan the best I could (a creative process without a pump, since the plug is flat on the bottom of the pan - I actually cut a hole in the fluid bottle lid and "squirted" the fluid in by squeezing the bottle). After dropping the car, everything was wonderful again for the next two months.
    Recently, we've had a cold snap, and the tranny started acting up again. I have no leaks, so I am confused by this myself. I surrendered and took it to a shop, and they are quoting me 2400 Euro for a rebuild (I gave $3K for the car!). I guess I assumed that buying a German car in Germany would be a little less expensive to maintain (wrong!).
    I've read some things in other forums about speed sensors causing this problem...with intermittent electrical problems, I don't know if the diagnostic computers will catch everything or not.
    I spoke to the mechanic today, and I'll be out of commission 3-4 weeks. They told me that my tranny was a 5HP18 (A5S 310Z), but my 325i is not, to my knowledge, an M3. Like an idiot, I did not use the dealer, so this dealer removed/shipped my transmission for diagnosis and possible rebuild. I'm not sure how they can diagnose all the high-tech circuitry and preclude any of those parts being my problem.
    Anyone know for certain what tranny should be in this car? Is is a 1992 325i 4 door automatic, with an electric switch for "3-mode" operation (Sport, Economy and Traction, I think).
    Thanks!
    Toronto
    Quote Originally Posted by Bravo10000
    Thanks!
    Hey Bravo10000, my Scotchmen bimmer specialists have seemed to have figured out my problem. Apparently all it need was a tranny flush and new fliud AND filter ($286.35 CDN taxes in). Apparently the filter was the original from 92 and the fluid was more than likely the original fluid as well (I've owned my car since 2000 and have put on more than 200,000 km on it and NEVER touched the tranny).
    Over time things do break down filters, fluids, etc. and they just need replacing. In all my years with my baby i have never had to open up the engine or tranny for anything mechanical - seals/gaskets occasionally (this being the first for the tranny and they found no metal shavings in my pans)
    One piece of advise from the Scotchmen @ Thorold Imports - the tranny fluid level is to be checked with the BMW scanner from a cold start only and the plug is to be pulled out ONLY once the tranny temp is @ 35 degrees. This allows for proper fluid expansion to give an accurate reading. This could be total BS but I trust these guys with my baby and they have NEVER let me down - they are all semi-retired and live and breath old bimmer's!
    By the way, I've thought about the dipstick dilemma too, according to the Scotchmen, it's to stop idiots from over filling the tranny and blowing the seals - it actually makes sense because I've done it myself when is was 16!
    Hope this helps?
    Western Germany
    Hope this helps?
    Well thanks!
    Incidentally, though, I did take it for a "full service" fluid change/flush, but that didn't solve my issue at all. Mine has 160K kilometers on it. When I checked my fluid the first time, I did get the temp to between 30-50 Celcius as recommended...
    One other thing, though - I read that these transmissions were designed to have "lifetime fluid"...a bit of an optimistic approach, I think...but I suppose we'll see what happens once mine is opened. I'll be certain to post the results.
    I've read about and experienced some of the quirks with this model that I'll pass on. The "lock it twice" electric door lock issue among them, which I am also having - that isn't a real big deal. I also have a warning coming up on the trip computer telling me "Bremslicht Electrik - Betriebsanleitung" - translates to brake lights, but they seem to be working fine. I guess the original brake light switch on the brake pedal can be problematic. Then there's an occasional coolant leak - I think my radiator is cracked on the top, and lucky me, it is plastic on the top so no brazing to fix it. It leaks down just far enough to warn me at startup, then the warning goes away. Lastly, I think I have a worn wheel bearing on the front right - a little louder when turning left, and it doesn't stop when I brake.
    Overall the car runs great, these other issues are relatively minor and I'll fix most on occasional weekends.
    Western Germany
    Hey Amarentic -
    Looks like I get the car back this week - finally - and the good folks at the repair shop told me something interesting.
    The 5HP18 that was delivered in my 325i apparently has a history of tranny problems that are attributed to an undersized transmission oil pan. This low amount of fluid has been said to contribute to early/inordinate wear. He tells me that this is at least one big reason that the BMW automatics see so many problems at 100-130k miles. I thought it was a bit strange, but it starts to make sense when I hear that (a) you had issues at a mere 2 cups low, and (b) a half-quart seemed to temporarily resolve my issues (same amount by my math). Of course, he was passing this information on from a separate shop that does trannys exclusively, and being here in Germany, I presume that the lion's share of their experience is with Bimmers and Benzs.
    To my dismay, this ended up being a complete rebuild - costing me as much as the car is worth. The rebuilt tranny, however, is being delivered with an aftermarket "performance" pan. A little late in the game, maybe, but thought I would pass it on anyway. I don't know if the transmissions vary between US/Euro spec'd BMWs (mine is German specs), so it may or may not apply. I also don't know if it will affect ground clearance - I'll give 'er a look when I get it back.
    Hope this helps?
    Minnesota
    [QUOTE=Bravo10000]Hey Amarentic -
    Have them send the old pan back to you so you can compare them...
    Western Germany
    Default E36 auto tranny - An interesting twist
    Just heard something from my (soon to be former) mechanic that makes no sense to me.
    My mechanic calls me about my 92 325i, I have had it in the shop for 7 long weeks now. They've rebuilt my tranny completely, said the clutch was destroyed by driving in "limp home mode". The cause, as he stated, puzzles me. I had the ghost brake light OBC message concurrently, on and off, but my tranny was "limping" even when I had no "check engine" light.
    He tells me that one of the ignition coils going out may have caused my transmission problem? I've read plenty of posts about the ignition coils in the 92 E36, but nothing that ties it to transmission problems! Does this make any sense at all to anyone else? Granted, I am more of an old school shadetree mechanic, and even then I didn't get too far beyond the basics...but can these really be wired that tightly together? Or is just a local national trying to give the the American a cold, hard one?
    Equally as troubling is his statement that he can't isolate which coil is going out, and trying to sell me all 6 at 68 Euro (about 85 bucks) each - or saying that I'll have to wait until he can get a coil to test with, subbing out one by one until he finds the bad one. Sounds like BS to me - weigh in? Aren't these just wires, basically?
    92 BMW 325i (Euro) 4 door - M50/5HP18 Automatic
    Production Month 11/1990
    P E36 Lim 325i M50 ECE 19901100 L A
    Your car does not have a CEL light, this is only for U.S. specification cars, as it was required by the environmental regulations.
    If you have a tranny problem in Germany, go straight to a ZF repair shop instead to a dealer. The BMW dealer just sends it to ZF for repair and just marks up his commission.
    There are also plenty of remanufactured transmissions available in Germany.
    Here are some 5HP 18 for around 1000 EURO with 6 months warranty
    http://stores.ebay.de/AUTO-SB_W0QQco...dZ2QQpZ2QQtZkm
    Used parts you will find here
    http://search.ebay.de/BMW-E30_Auto-M...25QQsacatZ9800
    You also can ask on the German E30 board if someone has spare parts available you need.
    http://e30-talk.com/index2.php?
    For sure someone understands English if you do not speak German
    Coils:
    It is not that easy, you need an osciliograph for that to read the curves.
    Go to a Bosch shop, they are specialized in electrics/electronics and have the equipment to test them, and they also have coils, as they usually are made by Bosch.
    Western Germany
    I do have a light on the console...an amber light that just says "Check". I worked on the trunk wiring harness yesterday, and I think my bogus brake light warning is resolved...but I still have the "lock 'em twice" door lock issue.
    Thanks! Wish I had asked this 2 months ago - I have now paid double for this car. He ended up selling me used coils and replacing the valve cover gasket. I am handy enough to do this stuff, but lack the facilities as home and my landlord is about his pavestone driveway. We have a really nice "auto hobby shop" at three different bases in town, I suppose I could have done the work there.
    You mentioned the E30 board? I thought the 92 325i that I am driving was an E36? Or am I just reading too much in to this?
    Coils:
    Yep - he gave me the old coils, and they are Bosch.
    Thank you for your reply, I am sure that I'll bug you again in the near future...
    Western Germany
    http://stores.ebay.de/AUTO-SB_W0QQco...dZ2QQpZ2QQtZkm .
    For sure someone understands English if you do not speak German.
    Coils:
  1. E34 auto tranny?
    By xaviervp in forum 5 Series BMW
    Last Post: 09-24-2008, 05:54 PM
  2. Shift pattern when the tranny is cold.
    Last Post: 01-26-2007, 01:43 PM
  3. Auto transmission noise when cold
    By bmw540 in forum 5 Series BMW
    Last Post: 10-13-2006, 08:34 AM
  4. Upshifting problem when cold: 89' 535i AUTO
    By eli535 in forum 5 Series BMW
    Last Post: 09-12-2005, 10:00 AM
  5. Replies: 2
    Last Post: 09-22-2004, 01:42 PM
