Results 1 to 8 of 8
Thread: Door check repair
    Winder Ga.
    Default Door check repair
    Hello everyone, I'm a newb to BMW but I have been over on Volvospeed for a while. I got my 94 525i 5spd today and so far I am enjoting it
    I do however have a question about door check repair, I saw the repair on e34.net, but my check has broken off in the door. The write up says that He JB welded it for the write up repair. Id rather not do that. Is there another way to repair this, maybe a repair kit, if this is a common problem? I also have a Volvo 95 850 turbo and while door checks arent common to break other things are and sometimes there is an easy fix or sometimes even a repair kit. I want to repair this ASAP because I believe it has dented the door from the inside out.
    Its good to see a repair and advice forum for these cars and I look foward to lots of future use!!!
    Darrell
    PS: does BMW still offer owners manuals for this vehicle? I looked at ebay with no luck.
    Benneton (United Colors of)
    the door brake itself is about $40. this is what the guy jb welded in this repair. it is now floating around inside your door. the other "repair" part, the bent door part, can be fixed one of two or three ways. one, it may be possible to fix it using the koala motorsport door brake aftermarket fix if it isn't too far gone. i think that might be an additional $40. another, if the damage is bad enough is to weld in or use (jb weld?) and fix the door, which will probably cost a bunch of money. a third (im not familiar with) is to use washers in a manner similar to the koala motorsport fix, if it isn't too far gone.
    Jul 2004
    Quote Originally Posted by djscoggins
    Darrell
    Check out Brett Anderson, BMW master tech, for a door brake fix:
    http://www.koalamotorsport.com/parts-home.asp
    As for owners manual, not cheap, but Brett sells those too:
    http://www.koalamotorsport.com/lit.asp?s=5
    We sell a lot of door brakes. Hopefully, the brake itself is bad, and the sheet metal isn't damaged. If it is, buy the reinforcement plates with the new brake. We currently only sell them in stainless, but we'll probably start selling them in regular steel for those who want to weld and paint.
    best, whit
    Aug 2004
    Regional NSW, Australia
    Just make sure that when you are putting in the new brake (check) that you take your time fiddling with it to get it into place - it is really quite tight to get it in there.
    Whatever you do, don't force it as you might damage the window winder mechanism or window runners.
    Ask me how I know !
    "I'm not the village idiot.
    Winder Ga.
    Thanks guys! I ordered a plate and Im gonna try to use that for repair but if its not enough I know a good paint and body guy at work.
    Darrell
    Jul 2004
    Holly Springs,North Carolina
    Darrell
    Bentley also makes a manual for the E34 that is pretty well respected. Here's the link:
    http://www.amazon.com/gp/product/083...lance&n=283155
    Michael
    Mustbr8kfree
    1995 525i, Shadowline,EAT chip, Alpine
    Nov 2005
    Mo!
    You might also consider getting the owner's manual at the dealer. My local dealer was able to get one for me for cheap - under $15....
    If you are looking for a service manual, then the Bentley is the choice!
  1. CCM = check control module repair info
    Last Post: 11-04-2024, 02:33 AM
  2. broken door bracket repair - DIY
    Last Post: 02-04-2023, 05:50 AM
  3. check control buttom repair
    Last Post: 05-08-2010, 10:04 AM
  4. How to repair door panels, Is there an article?
    Last Post: 05-22-2007, 06:46 AM
  5. oil canister check valve spring repair
    Last Post: 03-18-2006, 04:53 PM
