.Originally Posted by shogun
Hope you can read that w/o registering first
http://www.the7seriesregister.co.uk/...showtopic=1197
Maybe you register here
http://www.the7seriesregister.co.uk/forums/index.php?
Technical library for E32 has about 40 topics
"You do not have permission to view this board"
I'm assuming this is a fix for blown darlington final stage resistors? I didn't know that such a thing were possible, if so.
Let's have it already
best, whit
HOW THE FAULT SHOWS ITSELF
This repair started after I had problems with my V8 becoming a V7 in the '7 Snow Whites and 1 Brown Dwarf' thread in the E32 'It's Broken/ How do I fix' section of this Forum. I would not have bothered writing up a single isolated fault but was informed by a DME supplier that this was a common fault with the V8 DME's.
It is always difficult finding what is to blame when one cylinder out of 8 fizzles out, in this case the fault was initially traced to one cylinder due to the colour of one of the plugs (hence the title of the original thread), 7 of them were VERY white, to the extent that I was worried about piston damage, but one of the plugs was quite brown, and wet. The brown is unburnt oil due to that cylinder being completely disabled, the white on the other plugs is due to fresh air that was passed by that cylinder upsetting the O2 sensor and leaning out the other pots.
I had a good listen to the injectors using a stick pressed to my ear (although a stethoscope would have been better), the faulty cylinder's injector was not doing anything. This is what is expected with an ignition failure, if the coil does not fire neither will the injector.
The current going to each coil is measured across a resistor in the wiring boxes above the cylinder banks, the lack of current in a coil is seen as a failure of that coil and the injector is disabled to prevent Cat failure and cylinder wash-down.
Attached thumbnail(s)
Timm....1993 E32 730i V8
Profile CardPMUser is offline
Report Post
Add this post to a multi quote queueQuote Post Go to the top of the page
Timm
post Mar 15 2005, 12:08 PM
Post #2
7 Series Guru
Group: moderator
Model Owned: 1993 E32 730i V8
Available to help other members: Yes
Full Real Name: Tim Meek
The injector could well have been faulty, but this can be tested with a meter set to AC volts (digital meter is best). With the wiring cover off, the injector connector can be probed (but don't push the two contacts together) for each cylinder. You should expect to see an AC reading of a couple of volts depending on the filtering within the meter with the motor idling. A missing drive will be seen as no volts at all.....
Report Post
Timm
Post #3
7 Series Guru
Group: moderator
The injectors should always have a live feed of the battery voltage (around 14V with the motor running), the other side is connected to the DME and is pulsed low. If nothing is happening it is time to check if the coil on the dodgy pot is firing. Unfortunately, there is no easy way to get to the coil wiring without pulling the covers off where the wires from the coil join to the wires to the DME. .....
Report Post
Timm
post Mar 15 2005, 12:09 PM
Post #4
7 Series Guru
Group: moderator
However, if you own, or can borrow an oscilloscope then it is easy to check the coil without breaking into the wiring by clipping the probe around the pulse feed to each coil......
Report Post
Timm
post Mar 15 2005, 12:10 PM
Post #5
7 Series Guru
Group: moderator
Each coil has a brown wire (negative return) and a green wire (battery voltage). Each coil has a third wire which is a different colour for each coil. The plan is to hook the probe around (but not breaking into) these individual wires. A good drive can be seen as a positive going pulse, short in duration with a long low period. In reality, the coil is switched ON for most of the time (by pulling the pulse input to 0V) then switching OFF the coil (and so the pulse input goes high) to produce the spark. With this capacitive pickup the pulses are very noticeable, my dead cylinder showed no pulse at all. If this is the same situation on your car first check that the coil is getting both the battery voltage and the 0V by disconnecting the coil connector (with the engine OFF) and then switching the ignition on and checking for those voltages. If all is OK then it is time to check that the pulse input is electrically connected to the DME....
I don't have a picture of the connector that connects to the DME but instead here is a picture of the DME's connector which will mate with the connector (er..obviously).... I have circled the contacts that are used for the coil outputs. You should be able to meter between each coil connector and one of the mating contacts of the DME connector. If all 8 reach here the wiring is OK (mine was).....
This post has been edited by Timm: Mar 15 2005, 12:10 PM
Report Post
Timm
post Mar 15 2005, 12:11 PM
Post #6
7 Series Guru
Group: moderator
OK....so....we now know that one coil is not firing and that the wiring is OK. Time to take the DME out and apart. To do this, see the thread in this section on how to fit a Star Chip (just below this post). Get to the point where you have access to the EEPROM....
Report Post
Timm
post Mar 15 2005, 12:12 PM
Post #7
7 Series Guru
Group: moderator
To the left of the last picture the output transistors can be seen under a long heatsink. There are 8 transistors, one for each coil, plus a couple of other bits, the regulator and an...um....something else... You now need to get the heatsink off...even at this stage it is obvious that one of the transistors has failed due to the burn marks near it.To get the heatsink off lever it upwards with a screwdriver, don't lever the insulator at the same time because it snaps the location pin off (ask me how I know)....... Lever each end a bit at a time, it is quite tight and springy, however, the transistors are quite hardy and do not mind at all....P.S. the red arrow points to the insulator clip, this will snap off if you try and lever the insulator up at the same time...
Report Post
Timm
post Mar 15 2005, 12:13 PM
Post #8
7 Series Guru
Group: moderator
Insulator off.....let's play 'spot the dead transistor'...no prizes....P.S. The transistor has not changed colour, it's the new one, I took the pictures after the repair.
Report Post
Timm
post Mar 15 2005, 12:14 PM
Post #9
7 Series Guru
Group: moderator
Here's the original transistor fitted. It's got a Bosch number on it but a replacement is the TIP162 from Farnell for a £4.41 (Order Code 426910)...
http://uk.farnell.com/jsp/home/homepage.jsp
Or for our non-UK readers:
http://www.farnell.com
The transistors can be measured using a meter set to 'diode checking' mode where the leg to leg reading will be different for the faulty transistor compared against the other ones (base to collector and base to emmiter should show continuity only with the POSITIVE probe on the base).
It was obvious who the Bad Boy was here due to the scorched insulator.... The base is on the left-hand-side of each transistor...
Report Post
Timm
post Mar 15 2005, 12:15 PM
Post #10
7 Series Guru
Group: moderator
Time to get the transistor out. I recommend using a solder-sucker and a temperature-controlled iron, flow some new solder into the joint to start with, it makes the solder flow a lot better. As the transistor leg is a good fit in the hole (and the hole is through plated) it is possible that you will not get all the solder from between the leg and hole, a little wiggle will soon release the transistor. The new transistor will need to be prepared as the heatsink will be longer than required. This needs to be cut half way across the hole and then filed into this final shape. Bend the legs of the transistor to the same shape as the old one and place it in the PCB making sure that it stands at the same height as the others....then solder it in....
P.S. Never cut the heatsink with side-cutters or tin snips as the transistor will be damaged due to the deformation of the metal...
Report Post
Timm
post Mar 15 2005, 12:16 PM
Post #11
7 Series Guru
Group: moderator
OK, slip the insulator over the transistors and ensure it is located in the little dowels as shown before and then press the heatsink over the assembly. It is quite a tight fit, and still rather springy. Make sure that the heatsink is properly located over the insulator as shown here with the springy bits on the transistors and not between....
Report Post
Timm
post Mar 15 2005, 12:17 PM
Post #12
7 Series Guru
Group: moderator
Right....time to stick it all back together.
Follow the instructions on the Star Chip thread on how to re-assemble and refit the DME in the car.
IMPORTANT:The usual cause of a transistor failure is due to a faulty coil-over-plug unit. Although mine still worked when I moved it to another cylinder, I decided that for around £30 I would rather be safe than sorry...so I stuck a new one in.... We can play 'spot the new coil' now if you want...
Report Post
Timm
post Mar 15 2005, 12:18 PM
Post #13
7 Series Guru
Group: moderator
Do not be surprised to find that when you first fire the car up it will idle like a Nikasil infested 300K miler. That is quite normal, as we have just done a miracle 'reset' on the DME.
It will soon sort itself out after a bit of driving......
All done, time for a cup of tea......
P.S. Thanks to Mat for the transistor equivalent.....
There are two particularly useful pieces of information here. One is the replacement part number TIP-162 which is a robust 500V/30A darlington no longer readily available, and the other is the failure mode. In a quick search I found that only Mouser had an equivalent for it for about $8US.
Outside of an outright wiring problem, a failure of this transistor would most likely be due to an internal failure of the transistor itself, or, more likely, a failure of the coil that it's driving. It wouldn't take much more than one shorted turn on the coil to drive the collector current out of spec and either overheat the device or drive it out of its SOA. The poster that reported on his rework had the presence of mind to replace the transistor AND the coil.
If anyone's interested, I'll look around and see if there's a more readily available alternative to the part at Mouser, though the one that's there is priced about right for what this is.
