Results 1 to 3 of 3
Thread: exhaust flange (front to tailpipe) questiobn
    Dec 2005
    Brisbane Australia
    Default exhaust flange (front to tailpipe) question
    Hello everyone,
    just a quick question, i had one of the bolts fall out of the flange connecting the front and tail pipes i put some new bolts on the left most flange, I didn't want to do them up too tight (exhaust heat and expansion etc.) I was wondering whether these flanges are meant to be flush up against each other or is their meant to be some clearance. after doing up the bolts i took it for a spin but it still seems to be leaking a bit and i am wondering whether i didn't do the flange up tight enough or the gasket ring needs replacement.
    exhaust diagram
    i am talking about the flanges that are no. 5 in this diagram
    Dec 2005
    Brisbane Australia
    on second thoughts it would appear that i have lost an gasket ring somewhere, i am correct in assuming that the exhaust gasket ring seats in the groove on those flanges?
    Yes, you need gaskets and they usually only work one or two times around as they'll compress to fit the junction. Otherwise, there'll probably be an exhaust leak.
    best, whit
  1. Broken exhaust flange - anyone with fix pics ?
    By cmk in forum 5 Series BMW
    Last Post: 09-05-2008, 12:40 AM
  2. water and white smoke coming from tailpipe
    By Fraz06 in forum 5 Series BMW
    Last Post: 06-21-2007, 03:21 PM
  3. Little Help: WTB M30 exhaust flange??
    Last Post: 12-15-2006, 02:17 AM
  4. 540 exhaust flange
    Last Post: 07-24-2006, 02:47 PM
  5. The 3.64lsd needs the front flange swapped.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 03-04-2004, 10:00 AM
