....and under/over inflation maybe? I dunno, but it looks dangerous to me. Any history of recalls from Kuhmo?
Brian C.
This is what you could see from the outside... perfectly normal tire, just getting a little worn down, but not quite to the wear bar yet...
But, this is what the inside looked like... Honestly, about 75% of the circumference of the sidewall had seperated from the tread.![]()
Hard to see, but in this last pic, that's the hole in the sidewall where it blew out and lost pressure...
Something's just not right, huh? Notice the wear bar in the 2nd picture... not even THAT worn out. I admit, I have lowered the rear and have a little more negative camber than stock, but if Gordon had this same issue and he's on STOCK rear suspension... something's just not right. And I KNOW he drives that car like a grandma...![]()
Brian C.
There is nothing worse than a brilliant image of a fuzzy concept. -
.............Ansel Adams
funny, i had that exact problem with my Ecsta 712's
Dude - imagine if that tire was on an Explorer![]()
That is amazing damage... can see where I was headed there as well.....
Gordon Lawson
Niagara on the Lake
Ont., Canada
1989 535i 5speed "Eat'n"
The PO had installed a set of 255x40 x17 Nankangs.....The outside looked fine and a previous safety inspection the tester said....watch the uneven tyre wear....At inspection two time my indy refused to drive the car back to me cos steel belts were showing in exactly the same way!!!(we swap cars for the day auto e28 525es?<>e34 535)
Gone but not forgotten
Originally Posted by bimmerd00d
ditto!!!!!
my pirellis did that too on a stock suspension. missing chunks of tires on the inside.
