Thread: Fuel pump gurgle
    May 2005
    Fresno, CA
    Default Fuel pump gurgle
    Hey all, got an odd problem I recently started noticing.
    When I first fire up the car I will sometimes hear a gurgling/rumbling sound coming from the fuel tank. I first heard it after I had the car parked on a steep driveway with a low level of gas in the tank. I simply thought the pump was starving as the noise stopped once I backed the car out. However I've recently started noticing it doing the same thing with a full tank on a slight incline. Any ideas? Is the fuel pump dying or getting close to dying?
    The car runs great. Hasn't lost any power all the way to red line, fires right up and runs smooth, even when I hear the noise. Pretty sure the pump is original with about 130k miles on it.
    park it on a level surface.
    Jun 2005
    Cleveland, OH
    deep man... deep
    I miss my e34
    May 2005
    Fresno, CA
    Up...
    New Mexico
    Open up the gas tank from the trunk access and see if your return line has fallen off. I had the feed line come off on mine, which of course would not start at all.
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
    if the return line fell off there would be gallons of fuel under the car. It could have a small crack in the supply line but since the pump is in the tank it wouldnt suck air unless the pickup is messed up. Good idea to pull the pump out and inspect it.
    Quote Originally Posted by M20Turbo
  1. Fuel pump gone; Opel pump fit in BMW?
    Last Post: 09-27-2009, 08:51 PM
  2. Fuel Pump.... Thanks ED
    By joshuagore in forum 5 Series BMW
    Last Post: 12-01-2008, 05:27 PM
  3. Fuel Pump Replacement - Strange Fuel Levels
    By BIGRED in forum 5 Series BMW
    Last Post: 07-11-2007, 10:14 PM
  4. Fuel pump.
    By Rob in forum 5 Series BMW
    Last Post: 12-21-2005, 09:12 PM
  5. Fuel pump IN NEED
    By kyleN20 in forum 3 Series BMW
    Last Post: 08-21-2005, 11:10 PM
