in the us the 95 m3 was the only year of the s50, only slightly more work to do a s52 (which came in all of the later cars, not sure where you are but there may be more options) and just use your intake and wind up with more power, you'd be using your harness anyway just drill and tap for the 2nd temp sensor in the head, the boss is there. a m30 won't work with the m50 tranny as it's a different pattern, a m3 motor would be easyer as all you need is the longblock and you put all of your brackets/accessorys/manifolds on it
Originally Posted by
rob101
what is the S50 out of? M3 or M5?
