Originally Posted by
myles
Mine was very ticky after I set them to 0012thou(cold). I set it to 0011(cold) and it is much better, I should probably set it to 0010(cold) to get rid of the remaining tick. I didn't notice the idle get any more rough when I changed from 0012 to 0011thou.
Setting the valves tighter to cure ticking is a recipe for burned valves. The valve need seat time to cool off between cycles - setting them tighter shortens the seat time. Live with the tick and save your head.
BTW, some ticking comes from the fuel injectors so you'll never cure that.
Anthony
03/64 production
