Results 1 to 9 of 9
Thread: Sticking trunk button
    Aug 2005
    Toronto
    Default Sticking trunk button
    This is annoying year-round, but gets worse in the winter.
    The button to open my trunk is very sticky. When it's very cold, I'll push it in and it won't pop back out. I have to put the key in it and pull it out.
    What's the best way to lubricate it?
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    mines being a pain but it sticks when i try to puch it in. Havent washed the car in a month cause of the mud road or salt or wet roads etc...taking its tool on that button tho. Wish I had a remote opener for it.
    Nov 2004
    Middle England
    Quote Originally Posted by jaylebo
    Mine sticks in exactly the same way ... it has tiny deposits on it like the oxidation you get with aluminium alloy.
    I have tried WD40 and silicone - neither a complete answer though, so i'm interested in what others have to say on this ...
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Aug 2005
    Toronto
    Quote Originally Posted by zygoteer
    Neither of those is a lubricant, so I'm not surprised they don't work. I'd like to know what does work, though.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    Nov 2004
    Middle England
    I don't quite follow that then, as both of the cans show the word 'lubricates' ... maybe I'm missing something here.
    I used the WD40 primarily to first dispel any moisture, then the after drying it as much as I could, (I don't really like the greasy/oily residue WD leaves) I then used a filtered airline to get out any remaining, then I used the Silicone 'dry lubricant', as this is unlikely to coagulate or freeze.
    ... seemed like a reasonable plan to me ... but was only partially succesful - I think I will have to strip & clean the mechanism though, as I suspect oxidation is the real culprit of the sticking
    '86 F288 69k miles
    www.pyghtle.com
    I used PB Blaster, still must be a buildup of crap under the seal.
    Aug 2005
    Central Ca.
    I've always used a powdered graphite. Put a nice coating on the key and run it thru all the locks (remember to wipe it off your keys... it leaves a pretty ugly stain in your pocket). I then put some on my fingers and rub the outside of all the pushbuttons. Worked great on 35 year old locks for me.
    Rob
    Nov 2004
    Middle England
    Its not the lock itself that is the problem, but the actual chrome button sticking in the depressed position when it is opened.
    '86 F288 69k miles
    www.pyghtle.com
    Aug 2005
    Toronto
    I think he's saying you can rub it on the outside of the button and it will help. I'll try it.
    Re: WD-40 and silicone, I guess they do lubricate a bit, but their main purpose is to repel water. They're not a substitute for a good, dedicated lubricant.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
  1. Trunk release button...
    By Rick L in forum 5 Series BMW
    Last Post: 11-23-2009, 06:15 PM
  2. Trunk release button
    By bissellh in forum 5 Series BMW
    Last Post: 04-30-2007, 11:55 PM
  3. AC Button not "sticking"
    By 89535i in forum 5 Series BMW
    Last Post: 08-02-2006, 01:38 PM
  4. Replies: 8
    Last Post: 06-18-2006, 05:26 PM
  5. Sticking handbrake button
    Last Post: 11-22-2005, 02:38 PM
