Results 1 to 8 of 8
Thread: Identify these HG kit washers...
    Default Identify these HG kit washers...
    What are the washers circled in red for?
    These came in my headgasket kit and I am not sure where they go. The smallest one is copper.
    (I already have the rest of the parts pictured back in place.)
    Thank you,
    DanH
    1989 535iA 254k Miles
    1992 535iM 330k Miles
    Nobody knows?
    There are 4 sizes, one of each smallest and largest, two of each middle size. Maybe I'll have to look through my parts again to see if they match any of the old ones.
    DanH
    Boston & Attleboro MA
    Perhaps the gasket set covers all M30 engines and they are used in an older application.....
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Australia
    One of them is a crush washer for one of the bolts for the covering plate in the top right corner of the photo (12 11 0 002 735) (the little copper one). On that covering plate there is a white-ish patch around one of the bolt holes on the far right side, that is the spot this washer is meant to stop a leak.
    One should be for the timing chain tensioner piston bolt(07 11 9 963 355), the big one.
    My hd kit came with 4 new crush washers for the banjo bolts too (11 42 1 252 343).
    I had the same head scratcher with mine and found a home for most last night. I agree with myles, the largeest is definetely for the primary chain tensioner. The 'medium' sized ones look much like a crush washer for the block coolant drain plug(s) (my M50 has only one).
    Good luck,
    Dave M
    So, does the little copper one go on top of the o-ring washer(12 11 0 002 735)? (the one outside of the red circle just to the right)
    Also the old o-ring washer had a snug fit to the bolt(rubber went into the threads) and the new one is rather loose. Hopefully it will seal properly. And it is shown on the opposite side of the plate(11121254308) in the ETK picture.
    Quote Originally Posted by myles
    DanH
    Australia
    Sorry, I didn't notice the washer outside the red circle before, that one outside the circle is 12 11 0 002 735.
    I'm stumped. Keep the copper one as an ornamental key ring until you figure it out.
    Good idea... I figure there must be special place for it, since its a copper one.
    It may be M8 size, but I forget at the moment.
    DanH
  1. Where do these freaking washers go?
    Last Post: 11-07-2010, 09:37 PM
  2. Washers won't stop
    By dkaarb in forum 5 Series BMW
    Last Post: 10-11-2008, 10:22 AM
  3. Has anyone replaced their headlight washers?
    By Bimminator in forum 5 Series BMW
    Last Post: 07-27-2006, 10:13 PM
  4. Headlight washers
    By tgrandahl in forum 5 Series BMW
    Last Post: 05-19-2006, 06:56 AM
