Results 1 to 5 of 5
Thread: VANOS vs Non VANOS oil filter housing question
    PA
    Default VANOS vs Non VANOS oil filter housing question
    I looked on realoem.com and it shows the same oil filter housing for both the M50 variation of vanos and non vanos. Which, would imply, that the Non VANOS motor has the same oil filter housing but the VANOS oil outlet is plugged? Is this the case? The part number that is common between the two is 11421738639.
    There is only one bolt listed though - which would imply that both motors have a banjo bolt in that hole (assuming oil filter housing is identical). Theres no non-banjo bolt listed... so what gives?
    This would be a better way to supply my supercharger and turbo with oil supply.
    both the vanos and non v dont have the bolt listed in realoem?
    baton rouge, loserana
    most but not all had the hole with a plug screwed into it
    PA
    What did they have then winfred? No hole?
    none
  1. 525It M50 vanos: oilfilter housing leakage solved
    By werminghausen in forum 5 Series BMW
    Last Post: 12-24-2009, 01:19 PM
  2. oilfilter housing and CCM for sale for 525i M50B25 vanos
    Last Post: 11-25-2009, 01:28 PM
  3. Replies: 4
    Last Post: 01-12-2007, 05:56 PM
  4. Replies: 0
    Last Post: 01-12-2007, 04:10 PM
  5. VANOS engine fit a non-VANOS '91 525i?
    By joebigfun in forum 5 Series BMW
    Last Post: 02-18-2004, 12:08 AM
