Results 1 to 5 of 5
Thread: Fuel door removal
    Default Fuel door removal
    How do we remove the fuel door on our E34. I cant find anything in Bentley or search on this site
    If your fuel door hinge is broke you are better off breaking them off then replace it with a new one (less than $10.00 at the stealership). If you have to remove a good working hinge you need a small thin screwdriver and push two tabs in from the gas filler side of the hinge. There is a very small slit on the very back edge of the door hinge where you can insert the screwdriver and push aside the two snap-tabs. It looks easy but it is frustrating because you have to tug the door outward as you are pushing the tabs. Good luck!
    Default Yes, I got it. Not too bad but easy to break if you get frustrated
    Quote Originally Posted by Jazzman
    Philippines
    Is the fuel door supposed to lock together with the door/trunk locks?
    Default Mine does.
    Quote Originally Posted by jplacson
  1. Fuel cap door removal
    By BadAss95-530i in forum 5 Series BMW
    Last Post: 04-11-2008, 01:52 AM
  2. What does bentley say about fuel tank removal?
    Last Post: 12-18-2007, 08:43 AM
  3. help with fuel injector removal
    By Chip in forum 5 Series BMW
    Last Post: 08-21-2006, 05:12 PM
  4. Fuel Pump Removal
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 03-11-2006, 01:18 AM
