Results 1 to 3 of 3
Thread: Bill - do you have a preference for valve stem seals?
    Default Bill - do you have a preference for valve stem seals?
    Seem to be a variety out there - plain old stock ones, vitron based, silicon based, and teflon based.
    http://www.automotiverebuilder.com/ar/ar79842.htm - Discusses some options.
    My head has a teflon type and I think they look like the "1611" below (not 100% sure). I'm still consuming oil and am now wondering if I might have seal problem on the stems. Also, there seem to be several construction methods for seals. The typical kind seem to have a metal barrel and some sort of spring that pulls the seal around the stem. Like this:
    Then there are some that look more like this:
    Looks like the head is coming out for a camshaft change so I thought now might be the time to consider what might be a good option. Of course, while it's apart I'll measure the valve deflection to check the guides.
    Thoughts?
    Thanks!
    Bellevue WA
    86 Porsche 951 - Track Toy
    Default Almost everything i've done was with viton seals and
    a few teflon seals. They all use positive seals like you used. Almost every gasket kit nowdays comes with viton also..You shouldn't have any problem with either teflon or viton. How much oil consumption do you have?
    Quote Originally Posted by Jeff N.
    http://catalog.importcarparts.com/to...7012755HEB.JPG
    Thoughts?
    Thanks!
    PA
    Bill R., I am building an M50 non vanos for (more) boost and was thinking about redoing my valve seals. Should I stick with OEM from BMA (REINZ)?
    Jeff N. have you ruled out piston rings?
  1. When doing valve seals...
    Last Post: 07-07-2007, 05:39 PM
  2. M50 head refresh - what brand valve seals to use?
    Last Post: 08-17-2006, 08:14 AM
  3. Door Seals
    By Rory535i in forum 5 Series BMW
    Last Post: 11-24-2005, 05:03 AM
  4. change the valve stem seals on E34/M60
    By Rahimseven in forum 5 Series BMW
    Last Post: 09-24-2005, 08:52 PM
