Results 1 to 4 of 4
Thread: 5-spd Gearbox Question
    New Milford, Ct
    Default 5-spd Gearbox Question
    Trying to solve a mechanical issue with the 5-spd transmission (coupled to M20 motor). Shifting into reverse is a somewhat difficult task. I have to pull the lever to the left hard to feel for the slot and then push forward. After comparing the feel in a friend's BMW, it should be a routine gear change with no effort. The leather boot is torn (from previous owner's use).
    Overall, the shift lever is loose b/c all the linkage and bushings are worn. The engine and transmission have 180k miles plus.
    Is this problem related to worn synchros and gearbox internals and/or the loose gear shift linkage? Would an oil change solve this issue along with a repair of the linkage?
    TIA
    Support your American Flag Merchant Marine
    No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
    Dec 2005
    Independence Oregon USA - pop. 6000
    Think you diagnosed and answered your own question - replace all the sloppy linkage bits, not forgetting the difficult coupler at the transmission shift shaft (lotsa fun getting that clip off!) and the foam insert inside it. After doing that I betcha your problem disappears.
    Tom Walrod - Cured a '89 325i w/ 190,000 by doing the same thing
    agreed, probably the linkage/shifter issue.
    Aug 2004
    Dubai
    also you may check the clutch system. less compression casues the same.
  1. X5 Gearbox in an e34 540??
    By leicesterboy15 in forum 5 Series BMW
    Last Post: 07-06-2009, 05:21 PM
  2. M60 gearbox on M62
    By Jan in forum 5 Series BMW
    Last Post: 07-21-2007, 08:11 AM
  3. ATF for gearbox ?
    By Ross in forum 5 Series BMW
    Last Post: 12-07-2006, 09:02 AM
  4. Gearbox
    Last Post: 06-27-2006, 09:28 AM
  5. Steering Gearbox question
    By franks in forum 5 Series BMW
    Last Post: 03-26-2005, 04:44 PM
