View Poll Results: uhh as the title says
Voters
82. You may not vote on this poll
  • i have Nikasil with no probs
    46 56.10%
  • I have Alusil replacement with no probs
    31 37.80%
  • my Nickasil failed and needed/needs replacement
    2 2.44%
  • Alusil sucks too
    2 2.44%
  • I need intake gaskets but blame it on Nikasil
    1 1.22%
Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 77
Thread: V8 owners Poll Nikisil/Alusil
  1. #51
    Wichita, KS
    http://www.e38.org/koalamotorsport/v8shortblock.htm
    The numbers are on the right side of the block (from behind the car), by the #3 exhaust port. You can see it from below if you're lucky, or get an inspection mirror with an extending handle. Stick it down by the manifold from above and look around, you'll see a plate riveted to the block. Check the numbers and you're done. Easy.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
  2. #52
    the engine number...
    slide under the front of the car while it's on ramps. take a dope light or flashlight and paper and pencil. put your head directly under but infront of the starter (pass side US) look straight up, theres the number. Write it down, slide out and throw the paper away and wonder forever...lol.
    seriously thats where the numbers at.
    Quote Originally Posted by Oxford5er
    Well, I hope Mike Miller's correct, too, but in any case, where do I find the engine number, and is there a database or something to verify which material it is made of? Also, I have heard from several sources that the 3.0L tended to have less problems regarding the Nikasil block than the 4.0L. What have you 530i owners experienced?
    Wichita, KS
    Just FYI, my starter has a heat shield that made it impossible to see from below.
    Matt J.
    -Sold
    www.wichitabmw.com
  4. #54
    wonder why mine dont have one...?
    Quote Originally Posted by onewhippedpuppy
    Feb 2005
    Richmond, TX
    Probably had the starter replaced at some point and they didn't put the shield back on.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
  6. #56
    Sep 2004
    Quote Originally Posted by PAUL_ANDERSON123@TISCALI.
    My 540i seems to leak oil from the same place, not much, but stinks as it gets on the exhaust. What did the job entail?
    YES!!! I just had that happen to me, too! And I didn't catch it because my dad's Passat had a major oil leak, and he parked the Bimmer in its place, and I thought that the big oil spill was from the VW. They replaced the head gaskets and had to steam clean the underside of the engine thrice (I don't think I've ever used that word, but I like it) in order to get all of the oil off. I never noticed a bad smell probably because it was a slow leak.
    On a similar note, has anyone had a leak in the rear main seal btw the engine block and the transmission bell? I've got a minor leak, but want to know if it will get worse. My technician says to just monitor it....
  7. #57
    Sep 2004
  8. #58
    May 2005
    Fresno, CA
    Getting close to 133k miles here. Original Nikasil block. Engine had good compression (165-175 psi across all cylinders) at 120k miles when I bought it. Idles a bit rough, but the intake gaskets and PCV plate smoothed that out quite a bit. Doesn't burn a drop of oil and after 4k miles the oil still looks clean so I'm not too worried.
  9. #59
    yes theres a fluxuation off idle but usually smothes out before 2500,,, a smoth idle is a bad sign...lol
    Quote Originally Posted by Loppy
    Mine does. It's amazing. Soon as she warms up I could not even tell the motor was on in the car. And that was with broken motor mounts. Maybe thats why... (thread comming :eek
    It does lope a bit off idle up to 2000, then smooths right out again, so that's fairly normal?
    no offence but it probably wasnt failes, most likely other intake leaks as we presented in yout prior posts.
    Quote Originally Posted by saj3n
    I must have horrible luck! the only 1 who replaced a failed nikasil.
  1. Alusil coating in England?
    By Yaninnya in forum 5 Series BMW
    Last Post: 08-29-2006, 06:53 PM
  2. 4.0 ALUSIL (NGK) spark plugs?
    By 945401A_SPORT in forum 5 Series BMW
    Last Post: 05-23-2006, 03:11 PM
  3. Nikasil v. Alusil - Can you tell by VIN # alone?
    By NY535iManual in forum 5 Series BMW
    Last Post: 12-20-2005, 04:21 PM
  4. Replies: 15
    Last Post: 04-22-2005, 09:35 AM
  5. (maybe) buying a 540 this morning, need nikisil info
    Last Post: 03-18-2004, 11:12 AM
