Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Emergency: Sister Locked Inside Car
    PA
    Default Emergency: Sister Locked Inside Car
    Shes 1.5 hrs away from me, locked in her '95 530i. The door pin won't come up it just falls back down. The key turns in the ignition but it doesn't crank. She has no sunroof open tool. This is a big deal can anyone help me!
    Benneton (United Colors of)
    what do you mean "falls down"? is it an electrical pull down, or like a broken mechanism causing the knobs to fall down?
    was going to suggest that she drove home, and get somebody to open the trunk from the outside, force the allen key in somehow, but then i saw you say that it won't crank. if she's still in there, and you think its electical, i'd get her to jump in the backseat, pull it up, and "push" the wire back into the battery terminal clamp. i have a once/6 month problem where , when im about to start the car (all acc's come on), and i try to start it, it just goes "click". pushing the wire back into the battery terminal fixes it, but i think its an obc/code issue.
    car have an alarm?
    Aug 2004
    detroit
    call local police, have em come with a slim jim, or triple a, pop the hood and have someone hook up a battery, then roll down the window and dukes of hazzard it
    Jul 2005
    New York
    this looks like a job for your supercharger and 5th gear. what about turning the key to position 2 and opening the windows? i guess she's probly tried it all already. break the window and bust out?
    You're my hero.
    Kentucky
    Tell her to break the window or call 911.
    Dec 2005
    Mt. Vernon Ohio
    Sounds like it got tripped into the "hard lock" mode or whatever its called. I've done the same thing to my girlfriend and played dumb like "OMG your stuck!" Maybe your sis has a mean boyfriend to? :\
    1993 525iA M50TU
    Black on Black...need pics
    208,888 miles
    Pop the hood and have someone hook up the jumper cable... then have her see if she can unlock car from inside... or try passenger side door... hold pin up and open the handle.
    Bethlehem, PA
    Yeah, the second lock position on the driver's door lock. That's what it sounds like. But how would that be possible with someone in the car? Guess it could be a failure of the lock mechanism. That's a bear because everything's uncooperative when the lock is in that position.
    Jon, where is she located?
    Bethlehem, PA
    Default Where is she located?
    n/t
  1. Replies: 7
    Last Post: 01-08-2009, 12:53 PM
  2. Locked my sister in the e34 today......
    Last Post: 05-25-2007, 01:42 PM
  3. A Drawing my sister did of her '95 530
    Last Post: 11-07-2005, 08:49 PM
  4. Help Asap Locked From The Inside
    By ilya in forum 5 Series BMW
    Last Post: 06-28-2005, 02:52 PM
  5. Doors Locked with no battery inside , PLEASE HELP
    By Hernan Ortega in forum 5 Series BMW
    Last Post: 08-30-2004, 06:06 PM
