no the rhd models like mine, that also has had retrofitted cruise control had the wiring for the clutch above the pedals, the brake light switch is also there, although as you probably know cruise control uses the same switch to recieve its signal.Originally Posted by Toeks
there are many plugs tucked away up there, it may be some way away waraped up to the loom, but if you had the other wiring for the actuators and computer it will be there above the pedals.
also as well as a clutch switch you will need the switch bracket.
im unfamiliar with the later E34(1995), incase there was a difference, so check with others about it, there may also be differences between uk(mine) and other markets, but if its RHD id guess them to be the same
