I can get new pictures but nothing really to show since last time. I finally got the RPM signal to work. The BMW Bosch crank wheel is a 60 -2 wheel so i needed to install the MSnS-E firmware to enable crank wheel decoder to support this wheel else i'd need to retrofit a FORD EDIS 36-1 wheel which would be so hard.
So anyway, here's what is working:
MAP (manifold air pressure) sensor
Coolant Temperature Sensor (GM closed element)
Intake Air Temperature Sensor (GM open element)
Throttle Position Sensor
VR Sensor (RPM input)
Innovate Wideband O2 Sensor
I have datalogged a quick somewhat spirited drive. If you wish to view it you can install the datalog viewer by right clicking and saving link as and then running this installation file:
http://www.ideasandsolutions.biz/MSG...etup-v1.3b.msi
Once you have that you can download my Microsoft XLS spreadsheet file at:
and save it to the desktop as
whatever.xls
Then open the viewer application, load the XLS file. Go to options click RPM x100, click Calculation Fields and set both Wideband O2 to Innovate 0 - 5, then hit play
![Smile](images/smilies/smile.png)
