The guy on the German board has misread the datasheet. The BUZ71 can deliver 14A at 50V, which is 700watt. The 45 watt rating (actaully only 40 watt according to attached datasheet) is the amount of heat that must be dissipated thru the heat sink when the BUZ71 is operating at rated current and rated voltage.
http://www.jaycar.com.au/images_uploaded/BUZ71.PDF
Paul Shovestul
Originally Posted by
shogun
http://www.bimmerboard.com/forums/posts/136145
Another comment on a German board says (I translate this as good as I can):
"I would not use BUZ 71, because they only have 45 Watt, the BUZ 100 would be better, it has 250W and 60A. The fan max. pulls 30A, that are at 12V 360W, at 14V 420W. Based on this 2 x BUZ 100 are better than BUZ 71,
4*45= 180 Watt.
However, at low fan speed the MOSFETs become wormer than at highest speed. Or better use BUZ10 / 11."
Now it is the turns for the electric experts.
