Results 1 to 5 of 5
Thread: Head resurfacing question
    Aug 2004
    Regional NSW, Australia
    Default Head resurfacing question
    Haven't had the head tested yet but have been doing some research into various methods of resurfacing of the head if necessary. Just a couple of questions :
    If resurfacing is necessary, what sort of process should I be looking for - are CBN (cubic boron nitride) or PCD (poly crystalline diamond) machines necessary.
    In other words what roughness average (Ra) should I be aiming for ?
    Or are the older machines and techniques adequate ?
    (Was part of another thread but was getting lost).
    "I'm not the village idiot.
    Nov 2005
    http://www.aa1car.com/library/ar996.htm
    Try this out for some information on resurfacing. It appears that PDC is for aluminum and CNB for cast iron. I got this info off a machine tool insert site.
    CNB (Cubic Boron Nitride) Inserts
    These inserts provide an excellent finish on cast iron and have an exceptional cutting life. These inserts are also capable of handling the strain of high speed milling.
    PDC (Poly-Crystalline Diamond) Inserts
    These inserts have a thin coating of Diamond on top of a carbide insert. This insert is designed for cutting aluminum heads and blocks at very high speeds.
    Ceramic Inserts
    Default Zeuk if any of your shops have a comparator then you
    want in the 60 or so ra range for most cylinder heads.. its a case of not too smooth and not too rough. Most engine shops here are using a head resurfacing machine with a great big flycutting head that has many tool bits mounted on it that turns at a fairly slow rpm but pretty high surface feet per min...because of the size of the cutting head...When you're using one of these in good shape with freshly sharpened carbides you can get a 60 or even lower ra . There's newer equipment now that does a better job but very few shops are going to have them. I go to about a half dozen auto machine shops here regularly and they all still use the same stuff that i used in the 70's. For most general purpose work it will be fine. You actually want to see the surface of a head that was just done on the machine at whatever machine shop you go to to get an idea of how sharp their cutting bits are and how good a job it it do. An old machine can still do a fine job if its used with sharp tool bits and kept in good shape. Here's a link to the most common type of head resurfacer that i see around here
    Don't let them resurface it on one of the big belt sander looking head resurfacers, And yes the older machines are adequate if someone who's fairly skilled is operating it. Here's the specs on your m20 head, you can only machine off .3mm total or .012 thousands of an inch
    Quote Originally Posted by Zeuk in Oz
    Aug 2004
    Quote Originally Posted by laguner
    Ceramic Inserts
    Aug 2004
    Thanks Bill, just the info I needed !
  1. Diy Flywheel Resurfacing
    By tgrandahl in forum 5 Series BMW
    Last Post: 07-24-2008, 02:38 PM
  2. Dual Mass Resurfacing
    Last Post: 12-11-2006, 10:14 PM
  3. M50 Head question.
    Last Post: 06-04-2006, 02:36 PM
  4. Dual mass Flywheel Resurfacing -Myth or Fact.
    By GS535i in forum 5 Series BMW
    Last Post: 01-11-2006, 08:02 AM
  5. M5 Head Question...
    By TheGeak in forum 5 Series BMW
    Last Post: 02-25-2004, 03:01 PM
