Results 1 to 7 of 7
Thread: Engine Specs - Started via cam quiz
    Boston & Attleboro MA
    Default Engine Specs - Started via cam quiz
    Even though I have plenty to do, compiling a massive table of BMW engines is much more fun.
    In this post I will have the M30, M20, M50's & S engine specs
    HTML Code:
      <TABLE BORDER=1>
    <TR>
        <TD CELLBORDER=0>&nbsp;</TD>
        <TD COLSPAN=8 ALIGN=CENTER><B>BMW Engines</B>
        </TD>
    </TR>
    <TR>
        <TD>
            <TABLE ALIGN=CENTER>
                <TR><TD ALIGN=CENTER>Code</TD></TR>
                <TR><TD ALIGN=CENTER>Engine</TD></TR>
                <TR><TD ALIGN=CENTER>Years</TD></TR>
                <TR><TD ALIGN=CENTER>Displacement</TD></TR>
                <TR><TD ALIGN=CENTER>Power</TD></TR>
                <TR><TD ALIGN=CENTER>Torque</TD></TR>
                <TR><TD ALIGN=CENTER>Cam Config</TD></TR>
                <TR><TD ALIGN=CENTER>Duration</TD></TR>
                <TR><TD ALIGN=CENTER>Valves</TD></TR>
                <TR><TD ALIGN=CENTER>Intake</TD></TR>
                <TR><TD ALIGN=CENTER>Exhaust</TD></TR>
                <TR><TD ALIGN=CENTER>Bore</TD></TR>
                <TR><TD ALIGN=CENTER>Stroke</TD></TR>
                <TR><TD ALIGN=CENTER>Compression</TD></TR>
                <TR><TD ALIGN=CENTER height="40">Fuel System</TD></TR>
            </TABLE>
        </TD>
        <TD>
            <TABLE width="120">
                <TR><TD ALIGN=CENTER>M30B28</TD></TR>
                <TR><TD ALIGN=CENTER>2.8L I-6</TD></TR>
                <TR><TD ALIGN=CENTER>1969-1981</TD></TR>
                <TR><TD ALIGN=CENTER>2788cc</TD></TR>
                <TR><TD ALIGN=CENTER>192 bhp</TD></TR>
                <TR><TD ALIGN=CENTER>200 ft-lbs</TD></TR>
                <TR><TD ALIGN=CENTER>SOHC</TD></TR>
                <TR><TD ALIGN=CENTER>260 Degrees</TD></TR>
                <TR><TD ALIGN=CENTER>12</TD></TR>
                <TR><TD ALIGN=CENTER>46 mm</TD></TR>
                <TR><TD ALIGN=CENTER>36 mm</TD></TR>
                <TR><TD ALIGN=CENTER>86 mm</TD></TR>
                <TR><TD ALIGN=CENTER>80 mm</TD></TR>
                <TR><TD ALIGN=CENTER>9.00:1</TD></TR>
                <TR><TD ALIGN=CENTER height="40">Dual Zenith D-draft Carbs</TD></TR>
            </TABLE>
        </TD>
        <TD>
            <TABLE width="120">
                <TR><TD ALIGN=CENTER>M30B30</TD></TR>
                <TR><TD ALIGN=CENTER>3.0L I-6</TD></TR>
                <TR><TD ALIGN=CENTER>1973-1978</TD></TR>
                <TR><TD ALIGN=CENTER>2985cc</TD></TR>
                <TR><TD ALIGN=CENTER>176 bhp</TD></TR>
                <TR><TD ALIGN=CENTER>185 ft-lbs</TD></TR>
                <TR><TD ALIGN=CENTER>89 mm</TD></TR>
                <TR><TD ALIGN=CENTER>8.10:1</TD></TR>
                <TR><TD ALIGN=CENTER height="40">Bosch L-Jetronic</TD></TR>
            </TABLE>
        </TD>
        <TD>
            <TABLE width="120">
                <TR><TD ALIGN=CENTER>M30B32</TD></TR>
                <TR><TD ALIGN=CENTER>3.2L I-6</TD></TR>
                <TR><TD ALIGN=CENTER>1977-1984</TD></TR>
                <TR><TD ALIGN=CENTER>3210cc</TD></TR>
                <TR><TD ALIGN=CENTER>181 bhp</TD></TR>
                <TR><TD ALIGN=CENTER>195 ft-lbs</TD></TR>
                <TR><TD ALIGN=CENTER>272 Degrees</TD></TR>
                <TR><TD ALIGN=CENTER>8.40:1 / 8.80:1</TD></TR>
                <TR><TD ALIGN=CENTER height="40">Bosch Motronic</TD></TR>
            </TABLE>
        </TD>
        <TD>
            <TABLE width="120">
                <TR><TD ALIGN=CENTER>M30B34</TD></TR>
                <TR><TD ALIGN=CENTER>3.4L I-6</TD></TR>
                <TR><TD ALIGN=CENTER>1984-1987</TD></TR>
                <TR><TD ALIGN=CENTER>3430cc</TD></TR>
                <TR><TD ALIGN=CENTER>208 bhp</TD></TR>
                <TR><TD ALIGN=CENTER>225 ft-lbs</TD></TR>
                <TR><TD ALIGN=CENTER>264 Degrees</TD></TR>
                <TR><TD ALIGN=CENTER>47 mm</TD></TR>
                <TR><TD ALIGN=CENTER>92 mm</TD></TR>
                <TR><TD ALIGN=CENTER height="40">Bosch Digital Motronic 1.1</TD></TR>
            </TABLE>
        </TD>
        <TD>
            <TABLE width="120">
                <TR><TD ALIGN=CENTER>M30B35</TD></TR>
                <TR><TD ALIGN=CENTER>1988-1993</TD></TR>
            </TABLE>
        </TD>
        <TD>
         <TABLE width="120">
                <TR><TD ALIGN=CENTER>M102B32</TD></TR>
                <TR><TD ALIGN=CENTER>3.2L I-6 Turbo</TD></TR>
                <TR><TD ALIGN=CENTER>1979-1983</TD></TR>
                <TR><TD ALIGN=CENTER>252 bhp</TD></TR>
                <TR><TD ALIGN=CENTER>???</TD></TR>
            </TABLE>
        </TD>
        <TD>
          <TABLE width="120">
            <TR><TD ALIGN=CENTER>M106B35</TD></TR>
                <TR><TD ALIGN=CENTER>1983-1986</TD></TR>
                <TR><TD ALIGN=CENTER>3453cc</TD></TR>
                <TR><TD ALIGN=CENTER>227 ft-lbs</TD></TR>
            </TABLE>
        </TD>
    </TR>
     </table>
      <tbody>
      <tr>
        <td colspan="8" align="center">
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Well heres my beautiful html table that I can only get to view in Html in the testing area
    http://www.bimmer.info/forum/showthr...624#post124624
    Current
    2008 M5 6 Spd
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    very nice, are you adding the other engines to it?
    I will post a table that will include M20, M50, M52, M54, M60, S38, S50, S52, & S54 versions too
    So basically every engine in the 3,5,6 from 70s-90s and all the 6 cylinder M engines & of course the important E34 V8s
    Current
    2008 M5 6 Spd
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    wow! sounds like a lot of work to me, will definetly go into the archives though!
    Actually its getting out of hand, I cant stop addding details, here is the current list
    Code M30B28 M30B30 M30B32 M30B34 M30B35 M102B32 M106B35
    M50B25 M52B25 M52B28 M52B28 TU M54B25 M54B30 M56B25
    M20B25 M20B27 M60B30 M60B40 M62B35 M62B44 M62B46
    S38B35 S38B36 S38B38 S50B30 S52B32 S54B32 S62B49
    S14B23 S14B23 S14EVO S14EVO2 M70B50 M70B54 S70B56 S72B61
    Current
    2008 M5 6 Spd
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Hockinson, Washington
    You list the 1984-1993 m30 engines as having the same specs. This is not correct.
  1. Changing Euro Specs to US Specs?
    By brianwolf3 in forum 5 Series BMW
    Last Post: 03-06-2007, 01:18 PM
  2. M30 CAM Specs Quiz time...
    By JoeS in forum 5 Series BMW
    Last Post: 01-20-2006, 01:03 AM
  3. Help ... Engine stopped and never started again
    By grave77 in forum 5 Series BMW
    Last Post: 08-13-2005, 12:00 PM
  4. Engine drawings/specs
    By NielsGalan in forum 5 Series BMW
    Last Post: 02-28-2005, 09:23 AM
