Results 1 to 9 of 9
Thread: Two great questions......
    Default Two great questions......
    Mayga look, now for two boring ones. I did try the search, but maybe i missed something.
    1) I'd like to change the tranny output shaft seal on my S5D 310Z (91 525im). While a 30mm deep thin walled socket seems to be the convention, mine is definately larger. Does anyone know what size it might be? My calipers don't extend that far and I'm getting tired of buying and returning succesively larger sockets. Thought I'd throw that out there.
    2)Bentleys suggests "Molycote Longterm 2" or equivalnt for the slave cylinder pushrod and Microlube GL 261" for the clutch to input shaft splines.
    What might be the 'equivalent' and what do people use if anything. If there is still a coating of junk on the pushrod, do i really need to search this stuff out, or can I re-assemble without it?
    Thanks again,
    Dave M
    2" is about 50mm
    if thats what your asking??? lol
    Yeah, you got it..... 50.8mm. I'll go ask someone else.
    Dave M
    Jun 2005
    Cleveland, OH
    1) Don't ever have a clue.... The socket shuffle is a fun game to play
    2)Lubro Moly CV joint grease(molybdenum Disulfide) or Unirex S2 grease(BMW pn 83-23-9-416-138) I wouldn't... it should be about 10 bucks or so... ever from the stealership
    I miss my e34
    Pleasanton, California
    1) If your calipers are too short to reach, here's a couple of ideas.
    a) Use a compass, the drawing kind, reach in, adjust the width across the flats on the nut then remove and measure.
    b) Take a piece of pretty stiff wire or rod, a piece of a coat hanger would do, bend it over itself to form a "V", reach in adjusting the width of the points to match the flats on the nut, remove and measure.
    c) Take a piece of card stock, an old business card should work, cut the width enough to fit into the recess, eyeball the size and trim with scissors until you get the right width. It might take a couple of tries but it shouldn't be too hard to get close enough.
    d) With your calipers measure the inside diameter of the recess for the nut. Take a piece of clay and wedge it between a flat on the nut and the inside wall of the recess. Remove the clay, measure the width, multiply by 2 and subtract that from the recess dimension.
    Good luck.
    Curt.
    Curt.
    1994 530iT (gone but not forgotten since I see it every day!)
    1991 M5
    Thanks Curt, I'll choose door b) and try the wire technique.
    As for the
    , I'll have a look around. No dealer in vicinity, so I may have to improvise.
    Thanks both of you, thats the info i was looking for,
    Dave M
    Elm Grove Farm, NC
    Can we have a "smart-ass off"??
    Pairings for the first round could be 632Regal vs. Winfred.
    Who else????
    Bret.
    those is fighting words
    Quote Originally Posted by Rigmaster
    Who else????
    Bret.
    Jun 2005
    Cleveland, OH
    Ohhhh.. this should be fun
    I miss my e34
  1. If you're looking for a great driver?
    By saluki540i in forum 5 Series BMW
    Last Post: 12-25-2008, 09:25 AM
  2. Is this a great deal or what?!
    Last Post: 05-28-2008, 05:51 PM
  3. Great use of a BMW
    By Black 535i in forum 5 Series BMW
    Last Post: 11-23-2005, 12:56 PM
  4. A GREAT day for a drive...
    By Craig Wright in forum 5 Series BMW
    Last Post: 08-28-2005, 10:01 PM
