Originally Posted by
GS535i
Does anyone know what the spec height dimension is between the pressure plate bolting surface on the flywheel outer rim to the higher level of the clutch contact surface? This is for an E24/28 M30 flywheel p/n 11 211 289 244 .
So I've just scored on an excellent condition E24 (identical to E28) flywheel to eventually replace the dual mass unit in my '90 535i. The machine shop confirmed that a max. 0.005" cut followed by a surface grind would be all that was necessary to make the clutch face perfect - and that they would remove the dowel pins to restore the proper step down dimension for the pressure plate mounting surface. I can estimate that ledge height with a dial indicator - but if the flywheel had been ground previously, it may be a poor estimate.
Knowing where to find the spec dimension would be nice .... tia
(edit) Also, the starter ring gear has 116 teeth; is that the correct number and profile for the stock 535i starter?
