Results 1 to 7 of 7
Thread: LKM - very strange
    Vancouver, Canada
    Default LKM - very strange
    so i had the intermitten problem.. fixed it last year
    new problem a couple months back .. my right bulb doesn't turn on. i tried a different lkm and it worked so i know it's the unit and not something else..
    so yesterday i decided to try re-soldering for a third time and so i plugged the LKM into the car without the plastic housing so that i could see which relays were being used for what (the single is the fogs, the inner of the two is high beams while the outer of the two is lows) and surprisingly the light worked
    happily i put the plastic cover back on.. and the light didn't work.. odd. so i took it off.. and it works.. put it back on.. doesn't work
    wtf? there is nothing obstructing the relay.. i am really puzzled
    -inc
    '91 e31 850
    '90 e34 535
    '02 CBR F4i stunt/track bike
    '07 gsxr 750 stunt bike
    Default Can be as simple as temperature or as complicated ...
    as mainboard stress when in tha plastic box. Just keep your good work and resolder the culprit.
    You can put some presure on the relay with your finger, and check for intermitence in the lamp.
    Javier
    Wellington,New Zealand
    i vote for what shogun said.The cover puts some sort of physical stress on the assembly and a crack opens up....
    Gone but not forgotten
    Default And remember that besides the relay, it can be ...
    any other component in the power path from pin 2 to pin 22 of LKM connector, (includding soldering from pin 22 itslef to the board). Talking about right low beam light, isnt it?
    Javier
    Vancouver, Canada
    thanks for the suggestion.. i see what you're saying about stress on the unit. it is the right low beam.. how do i determine where pin 22 is?
    -inc
    '91 e31 850
    '90 e34 535
    dublin, ca
    i have one for sale if you want 50 shiped look in the classifieds section for my post
    Default Here you go, ...
    it is a picture of the connector where LKM plugs in.
    Javier
  1. strange bog..
    By alexander525 in forum 5 Series BMW
    Last Post: 03-11-2007, 07:49 PM
  2. Strange behavior
    By zack in forum 5 Series BMW
    Last Post: 01-29-2007, 08:58 AM
  3. this is a strange problem
    Last Post: 01-27-2007, 12:58 PM
  4. Strange Noise
    By GAM in forum 5 Series BMW
    Last Post: 10-03-2006, 08:27 PM
  5. Help! Very strange problem! Anyone seen this one?
    By Jeff N. in forum 5 Series BMW
    Last Post: 10-10-2004, 06:36 PM
