Problem : Vehicle has no brake lights whatsoever.
Information center says to check the "Brake Light Circuit" and refer to owners manual for further info.. Owners manual only gives Fuse # 46 as being related to this circuit. Are there any other fuses or junction boxes to check?? Where is the Switch located on the brake assembly??
Does anybody have any sources for used BMW Manuals? Need e36, e46, e32, e38, e39. .. Thanks in advance everyone!
Aaron
Ok, you should also check the brake light switch on the brake pedal.
