Results 1 to 10 of 11
Thread: headlight washer question: plumbing the 2nd tank
    Austin
    Default headlight washer question: plumbing the 2nd tank
    cant seem to figure out how to plumb the second tank. There is no filler neck and two fittings that could be made into supply and vent, but was wondering if anyone else made this mod on a v8. It's the last thing left on my repair and I don't want to have to remove the bumper cover after the shop had mounted it and made it all perfect.
    also, my fuse/relay panel is all in german. any idea which slot the intensive washer relay goes in?
    thanks in advance.
    geoff
    M5 bumper from a 91 with washer system going into a 3.0 530iT
    Calgary AB Canada
    Quote Originally Posted by 530iTouring
    thanks in advance.
    geoff
    My '91 M5 only has one honking big 8.5L tank behind the passenger headlights. Maybe that would be your best option. It has both the windscreen and headlamp washer motors separately installed.
    http://www.realoem.com/bmw/showparts...18&hg=61&fg=45
    Anthony
    03/64 production
    Austin
    I got that tank too with the bumpers, but it doesn't fit. It's totally in the way of the air box, which the second tank (for V8's) slips nicely under.
    Anyone have a pic of the relay panel in english?
    Dunlap Illinois
    I looked at the ETK on real oem and looked up your car. '94 530 Euro Touring. Is this the diagram you're looking for? http://www.realoem.com/bmw/showparts...82&hg=61&fg=45
    If not, maybe I didn't understand your question correctly. Now I'm trying to think if the Euro and the US relay panels are the same?
    Hope this helps somewhat...
    Jr
    Dunlap Illinois
    Now that I look at it, this might be the one you're after.
    http://www.realoem.com/bmw/showparts...56&hg=61&fg=45
    Dunlap Illinois
    I think this link might be able to help you with the relay location. It's in English, but I can't be 100% positive if both the US and Euro share the same electrical layout. It's worth a look. Hope it helps you.
    http://www.carsoft.ru/avtorepair/bmw...0.0/index.html
    Jr
    Austin
    thanks for the carsoft link. That should help.
    I have printed the second realoem link and bought all the parts related to the the second tank, but you will see that it does not have a filler neck and there is no plumbing parts to get water from the bigger tank to it.
    Dunlap Illinois
    The smaller tank uses the intensive washer fluid, it looks like there is a small filler next to the mounting screw bracket at the top of the tank.
    Intensive washer fluid is sold in small bottles and in some parts of the country it's illegal to use it straight out of the bottle, it must be cut with water. Imagine what it does to your wax job!
    Lori has the headlight washers and intensive cleaning on the windshield on her 2001 525, I use the intensive washer solution straight out of the bottle into the small container. I do not dilute it with water around this part of the country because of the dirty road conditons in wintertime. The undiluted concentrate cleans the headlamps and windshield like you wouldn't believe!
    Jr
    Wellington,New Zealand
    yeah its great in the winter here when you get that film on the windscreen 1 routine and its gone..mines broken must get to it.Hopefully its just the pump
    Austin
    Quote Originally Posted by Jr ///M5
    Jr
    OK, so I need to nix connnecting the two tanks together. That makes more sense. I didn't realize that the fluids would be different.
    Does the bentley have anything on this installation?
  1. Replies: 2
    Last Post: 05-27-2008, 10:22 PM
  2. Replies: 13
    Last Post: 11-12-2007, 08:36 PM
  3. washer fluid tank seal
    By ExtremeCloseUpGuy in forum 5 Series BMW
    Last Post: 08-12-2005, 10:16 PM
  4. Intensive washer question
    By simon-york in forum 5 Series BMW
    Last Post: 09-25-2004, 02:09 PM
