Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Red Check Engine Light Stays On
    KY
    Default Red Check Engine Light Stays On
    Hi Folks,
    I haven't had any bimmer issues in awhile so I haven't been on here to search for advice from you experts.
    Happy New Year!
    I was excellerating onto the on ramp of the highway this morning and my red check engine light came on. Of course red always means to me to stop and shut off the car. I did and checked the oil. I was down just about the lower line. So my husband said drive it carefully to the closest place you can get oil.
    Did that, one quart took it up over the first line. So no oil issues. The car has been running fine except a couple weeks ago it had a very very slight hesitation but it seemed to clear up. We got gas from a place not regular for us so that could of been the issue. The other thing I know I'm going to have to replace in the near future is the fuel pump. At 100K we replaced the first one and I'm familar with the humm they make. It's starting to make it again. And it's at just below 170K now.
    I know the owners manual states it's an emissions light not related to the oil. Could the slow death of the fuel pump cause this light to come on and stay on. I've only driven it about 20 miles with the light remaining on.
    Who knows. I'm going to drive it to see if it goes out. Because I understand the system is designed to have the light go out when the problem goes away. So we'll wait on it.
    In the mean time I would like to learn how to do this "stomp test". Can anyone bullet for me how to accomplish this to get the code?
    Thanks for all your help you all have help me keep my bimmer in tip top shape.
    By the way it's a 95 525i.
    Regards,
    Denise
    KY
    Ride safe and ride long!
    Jun 2005
    Cleveland, OH
    I miss my e34
    Have your fuel pressure checked if you suspect a fuel pump failure. Mine would throw a 1222 (Lambda Control 1) code with fuel pressure that was nearly half of what it should have been. Also serious hesitation and rough idle were present. Just my $.02
    Sep 2004
    A common cause of engine light coming on is that the O2 sensor(s) needs to be checked replaced. Even with the O2 sensor not being fully in spec the car often doesn't have any other symptoms and can be driven without any issues. Eventually the idle gets rough and the sensors need to be changed.
    KY
    Default re Red check engine light stays on
    Hi there,
    Is this link the "stomp test"?
    Denise
    KY
    KY
    Quote Originally Posted by ra_pro
    Ya know, the car has had a small hesitation and it also has a rough start as well but on very occasional. Depends on the temperature outside.
    I will have my husband complete the stomp test, change the O2 sensor, and check fuel pressure.
    Thanks so much and we'll let you know after the weekend what is up with it.
    Regards,
    Denise
    KY
    NC
    Default Yes, embedded in that link are these steps:
    Quote Originally Posted by caqueenslace
    Hi there,
    Denise
    KY
    1. Turn the ignition key on (without starting the car) and depress the accelerator pedal to the floor 5 times within 5 seconds.
    2. The check engine light will remain lit for 5 seconds, blink off, light for 2.5 seconds, goes off for 2.5 sec. and will start flashing the codes.
    3. Each code is separated by a 2.5 sec. pause. A 0.5 sec. blink then nothing means the end of the code reading. To read them again, depress the accelerator pedal 5 times again.
    Read the entire article.
    Bill B.
    95 525i
    Jun 2005
    Cleveland, OH
    Hi there,
    Denise
    KY
    Yeah, the page talks about how to do the test
    I miss my e34
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by billb
    .... Read the entire article.
    Why would we wanta do that :-)
    Post stealer....
    I miss my e34
    you might want to just reboot the computers before aimlessly replacing parts, the reboot will erase any codes so get them first then reboot. If the light comes back on after reboot check that code, should be more accurate.
  1. check engine light-???
    Last Post: 01-31-2009, 01:00 PM
  2. Check engine light...?
    By Rick L in forum 5 Series BMW
    Last Post: 09-12-2008, 11:44 AM
  3. check engine light flickers with engine miss
    By cobb535 in forum 5 Series BMW
    Last Post: 05-25-2007, 11:21 AM
  4. Check Engine Light
    By Spud in forum 5 Series BMW
    Last Post: 03-27-2006, 12:10 PM
  5. No Check Engine Light
    By mkiolbassa in forum 7 Series BMW
    Last Post: 06-23-2004, 03:59 PM
