The sylvania silver stars look pretty good in that picture, i think i may just get some of those.
setup. Thought I'd make a recommendation.
http://www.bimmer.info/forum/showthread.php?t=17475
Before you pick up a set of Silverstars check out this site. I had Silverstars before and they burned out in less than a year. I'm using the HIR9012 bulbs right now and I think they put out way better light and they are supposed to last as long as a regular halogen.
http://www.danielsternlighting.com/t...lbs/bulbs.html
It really should be a plug an play operation. The H1 HID bulbs should fit into Euro headlights that use H1 bulbs with no modification. As for the wiring, the input to the ballast is simply a stock 9006 plug. You may need to wire in a relay to eliminate a low beam OBC warning.Originally Posted by BigKriss
I have nothing to gain from the sale, just thought I'd pass along a recommendation. I am running a similar kit on my Depo headlights and it is actually quite simple to install.
