Results 1 to 10 of 12
Thread: Are the Bentley electrical schematics accurate?
    Midlothian, Texas
    Default Are the Bentley electrical schematics accurate?
    I've been trying to run down a short in my electrical system. The left side parking lights don't come on and the position number 4 fuse blows immediately when you turn on the light switch. The problem is that the label under the lid of the fuse box says that the number 4 fuse is for the left side parking lights and nothing else. But trying to trace the wire circuit using the Bentley's shows that the power comes in through the switch from the number 5 fuse.
    So, if the Bentley's is wrong how the heck can I figure out where to look for this short circuit? I need to get this fixed to get the car inspected.
    BTW this is a '95 525 and I made sure I was using the diagram for my car.
    Mark Hall
    '95 525iA EAT chipped (just one now )
    '98 528iA
    Default Mark, they aren't real accurate, as you can see here
    though fuse 4 and 5 are used... it should be 3 images, one may have to post after the first 2
    Page 2
    These pages are for the 1995 525 in the factory manual
    Quote Originally Posted by Hallmark
    Midlothian, Texas
    Default That is a little different,
    Reading this diagram it looks like the left side parking lights should be on fuse 5. Is that right? Should l be looking for a place where the fuse 5 circuit is shorting into the fuse 4 circuit?
    Thanks for the diagram.
    Mark Hall
    '98 528iA
    Default Check your mail.
    Javier
    Edit: Mail did not go trough, but Bill already post the 1995 drawing for you, so no longer needed.
    Default Yep, and i'd venture to guess that the switch itself is a
    good starting point, i'd check it to see if it was shorting internally when you turn it on..
    Midlothian, Texas
    Default I did a quick check by switching switches...
    I took the light switch from one car and swapped it with the other. I replaced the fuse in #4 and it blew again (I'm going to have to buy fuses by the case at this rate). Where else can these circuits cross? In looking at the diagram you sent I see an elipse with CDN in it. What does that stand for?
    Mark Hall
    '98 528iA
    Default I'm pretty sure that indicates thats for the canadian version with
    daytime running lights..., you would look at the other one instead.
    Default Try switching lkm's from one car to the other
    Mar 2004
    When you get tired of replacing fuses install a small wattage light bulb in place of fuse. Bulb will glow bright while short exists.
    Is the parking light bulb on the trunk lid rather then on the quarter panel? If so I'd check the harness that runs along the left side of the trunk lid hinge. This bundle gets a lot of exercise with opening and closing of truck, and these wires have been known to fail.
    Paul Shovestul
    .......I'm going to have to buy fuses by the case at this rate.
    Default good point, i had it stuck in my mind that it was the
    front parking light but that wasn't stated anywhere other than my imagination
    Quote Originally Posted by Bellicose Right Winger
    Paul Shovestul
  1. How accurate/reliable is Carfax?!?!
    By RockJock in forum 5 Series BMW
    Last Post: 11-15-2007, 02:33 PM
  2. Electrical schematics
    Last Post: 03-06-2007, 03:01 PM
  3. OT: cable schematics
    By jbourke in forum 5 Series BMW
    Last Post: 06-19-2006, 06:00 AM
