Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Ah...the joys of wideband tuning!
    Default Ah...the joys of wideband tuning!
    Finally...finally...the MAF curve is just about right. The car is really running quite well. A/F Mixture ranges from ~15:1 to 12:1 depending on load and acceleration. Light throttle feels just about right between 15 and 14 to one. Stuff it and the mixture richens to between 13 and 12 to one.
    Car's running open loop as well. Really the only way you can tune anything otherwise the mixture jumps around quite a bit; hard to tell where the map is vs. the ranging corrections of the ECU. I'm thinking I may just run the car open loop all the time.
    NEVER could have got this setup without the Innovate LC-1 wideband. It's really a great tool. Of course, there is some labor of love here. I think I've gone thru about 25 interations of the MAF curve to get to this point. Still have some more work to do but it's going to be some pretty fine tuning vs. the more or less gross adjustments that I've been making up to now.
    Another interesting observation is how FAR the mixture has to be off to trip the CE light. In closed loop, the car will work very hard to correct the mixture even when it's grossly off. This of course leads one to believe that they have the MAF setup correctly when it's not near where you need it to be.
    Next tweeks will be some added fine tuning in the 2700 to 3200 RPM range. With the stepped down diffy, the car runs about 2700 RPM at 70mph. Interestingly, the chip wants to push the mixture towards 13:1 or richer at this point. Or...I may just have a slight fat spot in the curve here. Anyways, I think I can get a little better highway MPG if I can move the mixture just a tad leaner here.
    Also, I have some more work to do in the 4500 + RPM areas. While I'm in the ballpark here, I'd like to do some more checking with the WOT setting on vs. off. My observation is that with the WOT setting on, the car runs rich (12:1+). However, with the WOT off, I'm not sure that I'm sending the maximum voltage to the ECU via the MAF. I'll have to setup some trace logs and watch the voltmeter to see what's really happening here.
    With all this, car still drives like a car with a hot cam. Don't have the really grunt down low that you might like for a city car. A cam change to a shorter duration cam is in order (and in the works). On the highway, the car pulls damn solid. 3rd and 4th gear acceleration on cam is impressive; car is pulling very strong at 80MPH in 3rd gear and keeps right on going when you hit 4th.
    Anyways...lots of fun and I'm learning quite a bit. If anyone ends up with a Pro-M MAF setup, contact me and I'll share my curve settings. They should get a stock motor pretty close I would think.
    Cheers!
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Dec 2005
    South Africa
    Jeff,Have been using INNOVATE MOTORSPORT`S LC-1 for over a year now..
    Excellent bit of equiptment..So much so,that Ive purchased the whole shebang-The case,datalogger,multichannel logger,gauge....all of it..
    As you say,makes life easier..
    Do you have something posted on your MAF setup?You running old Motronic here??
    Sorry,have not done a search on this yet..
    You could try setting the analog1 output to a very narrow range, like the 2nd view provided, for tuning in 'open loop'.
    Innovate has suggested afr ratio's for street-driven 4 stroke motors:
    14.6 : 1 is dangerlously lean under power
    14.2 : 1 is lean, max power
    13.5 : 1 is max power (suggested for blown motors?) the range I've targeted
    13.2 : 1 too rich for un-blown motors
    erased due to slander
    Default Barry...
    The MAF unit replaces the stock AFM - It used to be sold by Pro-M but the company has changed it's name and site; maybe Martin has the link stored? Works with the stock ECU.
    Thanks for the graph Martin, maybe I'll try that later today. Still have some more tweeking work to do of course.
    Quote Originally Posted by Martin in Bellevue
    Bellevue WA
    why would you want to go shorter duration, is it a little over cammed even while revving up over 3500?
    Default prefer to have a little more torque at mid...
    ...car's short of squirt in the 2500 to 3500 area - where you spend a lot of time in day to day driving. The current cam's about a 294 or so, going to a 284. Stock is about 268.
    Bellevue WA
    294 is a bit big for daily commute...where do they get these durations figures (ie: what lift) and what are the lifts for stock, 284 and 294? I would like to be a bit more knowledgeable in this area and see how these figures fit in with Detroit iron & cycle engines (if there even is a comparison at all).
    edit: what are the lift & Dur figures at .050?
    Default I'll have to dig out that information
    I have some details the MM and the Schrick cam but as I'm sure you know, getting common measurements on cams is not something everyone publishes.
    Anyone have the measurements on the stock 535i cam?
    Bellevue WA
    Jeff, what revs do you get max power at with the 294 cam ? Be interesting to see how it compairs to my 284/280 Schrick ?
    I've got this setting up to look forward to, i've bought an LC-1 to tune my stand alone ECU on my M30.
    It's got a good map but i've made some minor(new air filter and Exhaust) changes to the engine since it was mapped so i want to see whats going on with the AFR's.
    With my ECU and a lap top i can data log most of the engine parameters like revs/throttle angle/AFR's/etc so hope fully it wont be to hard to set the WOT settings, part throttle is going to be a lot more labour intensive compaired to WOT settings !
    It would be nice to compair AFR results with you guys !
    I read some where that 13:1 was the AFR to aim for max power but this conflicts with the info from Inovate ?
    Is 14:1-14.5:1 a good tick over AFR for a warm engine ?
    What AFR should i aim for on a cold engine at tick over ?
    I'm not going to start tuning just yet as i'm going to be fitting a new mid section of my exhaust and i've got a twin 60mm TB (if it ever arrives) that i'm going to fit to the other side of my inlet manifold like the B10 Bi-turbo so theres no point starting tuning just yet.
    Heres the TB, can't remember if i've posted about it on here or not ?
    Dec 2005
    South Africa
    Default Afr At Idle??
    There is no specific afr at idle for a specific engine..Let me re phrase that-Every engine will idle at the afr where it is happy to do so.This might be rich or very lean mixtures..Give it what it wants and is happy with.
    Same for cold start..Its got to be drivable from very cold..
    Kepp increasing the cold start value untill its drivable,but be carefull..A seriously rich mixture will be very drivable-up to a piont,obviously-but not good for the engine-never mind your wallet..
    If it were me doing the mapping,I would data map the std car with the std. management first..just to get a ballpark as to what mixtures are required..
    From there I would look at getting it pretty much the same AND THEN..start playing with the modified map..
    Ive done a few cars in my time,mostly using Haltech,Motec and Electromotive units..
  1. ECS Tuning
    By guinness in forum 5 Series BMW
    Last Post: 02-27-2009, 09:59 AM
  2. tell me about tuning the 533i
    By AngryPopTart in forum 5 Series BMW
    Last Post: 06-30-2008, 08:14 AM
  3. Factory Crossover tuning
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 07-31-2006, 01:21 AM
  4. PLX wideband o2
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 04-28-2005, 12:48 PM
