Results 1 to 10 of 13
Thread: Engine Vibration?
    Sep 2004
    Comox Valley, Vancouver Island, British Columbia
    Default Engine Vibration?
    I have been trying to track down a vibration that occurs in the car at specific RPM ranges, especially under harder accelleration. We put the car on the hoist and ran it in gear..the vibration starts at 1300 RPM, goes away at 1800 comes back again at 2300 to 2700 and on and on. We have tracked it down to a vibration in the engine/transmission (it occurred when the car was in neutral, and you revved it up...but it is more apparent when in gear), the tech figured it was either the harmonic balancer or the torque converter (BMW apparently sent out a bulletin, on this occurring with the converter, the bearing or the bushing wearing?)
    540i - 5speed auto
    Have any of you ran across this problem, of engine vibration?
    Cheers
    unless the vibration is obviously BAD these V8s do oscillate at different RPMs. Mine has a decent one at 1800 which feels like a miss but goes completely away at 2000 etc etc...same as you
    you cannot perfectly balance a 40 degree 8 cylinder engine to be perfect at all rpms, there has to be compromise somewhere.
    The v8 harmonic balancers DO go bad, but the engine would likely stall or sputter at anything above ~ 2700 rpm.
    Sure you don't have a collapsed engine or trans mount?
    best, whit
    Great reminder Whit! Bad mounts really can transmit some vibration.
    Sep 2004
    Default mounts
    I did check both the transmission and the engine mounts, and they all seemed to check out.
    I did replace the transmission output shaft bearing and the bearing halfway down the driveshaft, so it seems to me that there has been some problems in the past with the driveline.
    Does it make any sense that the torque converter has a bad bearing or bushing, thereby creating a vibration. BMW did have a bulletin out mentioning a failure here.
    May 2005
    central coast nsw au
    the centre bearing and flex disc are due at about 200k anyways. who did them and was the shaft put back on correctly? how did u check the tranny mounts and the engine mounts? if u dont lift em all the way up, especially the engine mounts u wont know. my money is on the engine mounts before heading into other complicated stuff. if the engine mounts havent been done for a while then its not going to hurt to do them. they are cheap and quick to do and then start looking for a vibration if there is still one.
    Sep 2004
    Default will do
    We checked the engine mounts at my local (they are pretty good, I get to be there at all work) the mounts were checked with a bar and prying.
    I will however change the engine mounts, the tranny mounts were done when the flex bearing was done.
    Thanks bud,
    May 2005
    u can drop the front plastic protective plate and under the front of the sump it is safe to put a block and then jack it right up from that point. its the only way to really see what the mounts are doing. i am just an amatuer and the first time i looked at the mounts i though they looked bloody brilliant. my father in law , whos a mechanic, then showed me much to my horror that when he jacked it up the mounts were completely separated. just a thought. good luck anyway
    Default And even if they aren't they will be after you
    jack the motor up like that
    Quote Originally Posted by mattyb
    May 2005
    maybe allow me to clarify because im not going to argue with that bill. i dont mean rip into the jacking and tear em apart, rather lift the engine to the point where its plainly obvious that they are good or stuffed. i found that it only took a small lift to see that they were separated, maybe 5-10 mm ,thats all
  1. Replies: 12
    Last Post: 02-27-2009, 11:49 AM
  2. fluctuating engine vibration when at a steady RPM
    By marckula in forum 5 Series BMW
    Last Post: 12-08-2006, 04:34 AM
  3. M50TU: Body vibration at varying engine speeds
    By theirongiant in forum 5 Series BMW
    Last Post: 06-22-2006, 04:34 AM
  4. Engine vibration and flywheel
    By Claude in forum 5 Series BMW
    Last Post: 05-25-2006, 01:32 PM
  5. E30 318i M40 Engine vibration at 2500rpm
    By chaz in forum 3 Series BMW
    Last Post: 12-11-2005, 09:08 AM
