Results 1 to 10 of 13
Thread: POR-15 preparation products, question....
    Default POR-15 preparation products, question....
    Purchased some POR-15 yesterday (ouch, a bit steaper than 'rust check' brand). The destructions state that a water-based cleaner should be used to prep the surface. Of course, they also pitch their own marine cleaner which my source does not carry.
    Are they any alternatives, or a commonly used solvent, safe for POR-15 prep. I have a number of small areas (most on the front cross-member) to address now that the engine and steering box are out, most of which were coated with a film of various petroleum based substances.
    Ive already cleaned brushed and wiped with rubbing alcohol. Might this be sufficient? I have no experience with POR-15.
    Dave M
    clean with your favorite chemical solvent, after all the grease and stuffs gone use hot water, a brush and dish soap?
    Alcohol doesnt cut grease well.
    Whats 'dish soap'? Maybe I should ask my wife.
    Thanks jeff, i found the marine degreaser in town and will do as told!
    Dave M
    what planet are you from again?
    Whats 'dish soap'?
    Aug 2005
    Toronto
    Dave M
    FWIW, I have Marine Cleen and it smells just like turpentine. I bet turpentine would do the same job, and will rinse of with water (won't it?).
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Dave, buy a box of brake cleaner and go at it. We use CRC stuff, but they're all the same. Best of both worlds: a strong solvent that leaves no residue and quickly evaporates. A can of brake cleaner and a good wire brush will take care of practically anything on the car.
    best, whit
    That was a chauvinistic comment. Get it? If not, I'l ty harder next time
    Dave M
    Jun 2005
    Cleveland, OH
    Dave M
    Be nice... Jeff has had a couple bad days...
    I miss my e34
    PA
    doesn't a 'couple' equal to two? Jeff, how old are you?
    jk.
    Quote Originally Posted by dacoyote
    Sarcasm is not a friend of the internet. I meant no insult. If you're there Jeff, I've polished off a 26'er and just finished hand cleaning the block with 'marine cleaner'.
    Off to the after hours bar,
    Over and out,
    Dave M
  1. Detailing Products Poll:
    By artguy in forum 5 Series BMW
    Last Post: 09-14-2007, 05:11 PM
  2. Recommended Detail products
    By s_ribbens in forum 5 Series BMW
    Last Post: 06-01-2006, 11:57 AM
  3. preparation to switch to synthetic oil
    Last Post: 03-21-2006, 08:13 PM
  4. Taking the car to the track - preparation questions
    Last Post: 03-09-2005, 09:15 AM
  5. bg products
    By chefdanny121 in forum 5 Series BMW
    Last Post: 12-07-2004, 11:40 PM
