Results 1 to 8 of 8
Thread: help with seat twist fix
    Hobart, Tasmania, Australia
    Default help with seat twist fix
    Fellow 5ers, I have a variation of the seat twist problem. The seat seems to have a permanent twist, no doubt caused by the shrinking cable problem, but there seems to be no problems with the cable now.
    My guess is that the previous owner fixed the cable, but didn't properly align the seat before doing so.
    Is there a simple way of disconnecting one side of the seat so I can bring it into alignment - directions on what to do?
    If not, do I have to go through the whole remove the seat thing as shown on the various seat twist fix websites?
    David
    Long Beach, CA
    Quote Originally Posted by 95-540iLE
    David
    The only way I was able to unbolt the motor to remove one side of the cable was to unbolt the seat. You can then get the seat aligned right and reinstall the cable and seat.
    if they spliced the cable somewhere its possible, but...you will only be guessing if its correct.
    Another idea is to unplug one of the motors and adjust the seat, then plug it back in? I have no idea if it would work.
    That what was I was hoping I could do. I had a poke about under the front seat, unplugged a couple of the plugs etc to see if I could spot something that would disable only one side of the backrest - but I couldn't find an easy option.
    I was hoping someone could point me in the right direction.
    If not, I guess the seat comes out!
    Cheers
    David
    taking the seat out isnt hard at all, I found it easier than all the time I spent messing around trying to fix it without remiving it...lol
    Jan 2005
    Melbourne Australia
    dave, ive got the same slight twist and when i had to fix it all appeared to be fine, so i pulled both cables out and adjusted them manually untill they were right and then mounted it all back up. good as gold now.
    i used the seat fix thread in the aussie iLE forum
    Did you have to take the seat out?
    Quote Originally Posted by Aussie e34
    Long Beach, CA
    The seat doesn't have to come out of the car, just unbolted to lift the front up to get to the seat motor.
  1. Seat twist help
    By shelldrake in forum 5 Series BMW
    Last Post: 01-29-2023, 10:16 PM
  2. My seat twist fixed itself...
    By rcbrown23 in forum 5 Series BMW
    Last Post: 11-09-2007, 12:46 PM
  3. 90 525 seat twist
    By 525ikicker in forum 5 Series BMW
    Last Post: 12-29-2006, 10:08 AM
  4. Seat Twist Fix Gone Wrong!
    By GatorGambit in forum 5 Series BMW
    Last Post: 09-04-2006, 09:01 PM
  5. e34 seat twist questions.
    Last Post: 07-11-2006, 10:16 PM
